Universal Bit Kit
  • Universal Bit Kit / New
  • 360°
360
Universal Bit Kit
The complete bit set for any repair enthusiast.
$99.99
$99.99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Detalhes do produto
Descrição
Descrição
  • 128 steel bits in both 4 mm and 1/4" sizes for precision work and large torque application.
  • CNC machined aluminum driver handles for both 4 mm and 1/4" bits provide plenty of grip while driving screws.
  • Elegant oak case keeps all components secure and conveniently displayed.
Bit List
  • Phillips 000, 00, 0, 1, 2, 3
  • Flathead 1, 1.3, 1.5, 2, 2.5, 3, 3.5, 4, 5, 6, 7, 8 mm
  • Torx T2, T3, T4, T5
  • Torx Security TR6, TR7, TR8, TR9, TR10, TR15, TR20, TR25, TR27, TR30, TR35, TR40
  • Hex 0.7, 0.9, 1.3, 1.5 mm
  • Hex Security 2, 2.5. 3, 3.5, 4, 5, 6, 7, 8 mm
  • Hex SAE 1/16
  • Hex Security SAE 5/64, 3/32, 7/64, 1/8, 9/64, 5/32, 3/16, 7/32, 1/4
  • Nut Driver 2.5, 3, 3.5, 4, 4.5, 5, 5.5, 6, 7, 8, 9, 10, 11, 12 mm
  • Nut Driver SAE 1/4, 3/8
  • Square 0, 1, 2, 3
  • Pozidriv Pz0, Pz1, Pz2, Pz3
  • JIS J000, J00, J0, J1
  • Torq-set 6, 8, 10
  • Tri-wing 0, 1, 2, 3, 4
  • Tri-point Y000, Y00, Y0, Y1
  • Pentalobe P2, P5, P6
  • Clutch 1, 2, 3
  • Gamebit 3.8, 4.5 mm
  • Spanner 4, 6, 8, 10, 12
  • Triangle 2, 3 mm
  • Spline M5, M6, M8
  • Oval Bit
  • SIM Eject Tool
  • Magnetic Pickup Tool
  • Schrader Valve
  • Hook and Loop Fastener
  • 1/4" to 4 mm drive adapter
  • 1/4" driver to 1/4" socket adapter
  • 1/4" driver to 3/8" socket adapter
  • 1/4" socket to 1/4" driver
Vídeo do Produto
Histórias de Reparos
Avatar do usuário
Benjamin Rodriguez's Story Photo #1013595
Meu Problema
Battery is damaged
Minha Solução
Quite easy
Meu Conselho
If you put more guides that are good to learn
Avatar do usuário
Meu Problema
User spilled coffee onto their keyboard, computer shut off.
Minha Solução
Better than anticipated. First in-house repair of a logic board.
Meu Conselho
Magnetic board to organize screws and the 128-bit kit to have everything.
Avatar do usuário
Meu Problema
My Apple watch screen suddenly came off of the frame as the adhesive material must have some how been damaged. So the screen was hanging from the frame by a few tiny connections!!!!
Minha Solução
I took it to Apple to get it fixed and they quoted me 3 weeks time plus 275$+13% tax to fix it as I was out of warranty . . .
Avatar do usuário
Meu Problema
The Problem started when my dog knock over water on my wife mac.
Minha Solução
The repair went well, though i should of bought the ifix it business tool kit because some of those cable are really small.
Meu Conselho
I never done a repair that did not had any remaining screws. Just follow the step that Ifix it provides and you w . . .
Avatar do usuário
Meu Problema
It had been dropped
Minha Solução
My blind grandmother could have fixed it....
Meu Conselho
If you need help go to ifixit
Avatar do usuário
Meu Problema
The battery of my Macbook Pro 15 - 2011 died on me.
Minha Solução
It took about 7 min and was great.
Meu Conselho
Just read the instruction before you order.
Avatar do usuário
Meu Problema
The current 500GB drive had run out of space, so we upgraded to 4T.
Minha Solução
Everything went well, however a word of caution. The video cable mount is very tiny and you need small hands to reseat it.
Meu Conselho
You don't need to remove the LCD screen, you can reach the screws that hold the drive in place by simply liftin . . .
Avatar do usuário
Meu Problema
Problem - Daughter's Boyfriend Electrical Engineer - Idea for gift!
Minha Solução
He loved it! Several times while he was at our house, I found him simple pulling out each bit and playing with the two drivers. My daughter said he had to hide them from his Dad. Maybe Dad will get a set of his own.
Meu Conselho
Oh yes, advice... . . .
Mostrar mais
