TR6 Torx Security Screwdriver
  • TR6 Torx Security Screwdriver
  • TR6 Torx Security Screwdriver / iFixit - Made in Germany
US$6,99
US$6,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Detalhes do produto
Descrição
Descrição
Use this precision Torx TR6 screwdriver for DIY or professional electronics repair. The Torx TR6 screw is a security screw used to secure hard drives, hard drive brackets, and is used in the 2014 Mac Mini. The screwdriver head is also known as the Torx Security TR6 and is compatible with standard Torx T6 fasteners.
The iFixit Torx TR6 screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision Torx TR6 screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Histórias de Reparos
Raphae Halim's Story Photo #890532
Raphae Halim's Story Photo #890521
Raphae Halim's Story Photo #890520
Meu Problema
The keyboard was faulty and Apple said it would need to change the entire upper case. So I thought I would do it myself as I love opening up and experimenting with stuff anyway :-)
Minha Solução
With the help of "http://www.insidemylaptop.com/how-to-rep..., it was a bree . . .
Tyler Kussee's Story Photo #1007012
Tyler Kussee's Story Photo #1007014
Tyler Kussee's Story Photo #1007013
Meu Problema
Needed the smallest torx ever
Minha Solução
I was surprised how quickly it came off.
Meu Conselho
Steam controller doesn't require security model screwdriver.
David Thomas's Story Photo #1426209
Meu Problema
Laptop keyboard was failing.
Minha Solução
My mid-2010 MacBook Pro 15" keyboard was going out and leaving me frustrated. The nearest repair shop wanted $175 to fix it, and I am on a very tight budget, so I attempted it myself. I dropped $17 on a new keyboard and $47 on your toolkit, and fixed it myself in about an . . .
Christopher Rodgers's Story Photo #1306604
Meu Problema
My 2014 1.4ghz 500 gb 5400rpm HD Mini has been slow from the start and only got more so as the years went on. Rather than buy a new machine, found a Samsung EVO 850 2.5" at $130 for the SSD and $35 or so for the iFixIt tools and voila.
Minha Solução
Ordered a USB to SATA cord for $15 from Amazon and connected the . . .
Galen Grote's Story Photo #873130
Meu Problema
The fan on my Macbook Pro 13" (mid 2012) was making this grinding noise. I took it to the Geek Squad (Best Buy) and they told me that it could cost in excess of $500 to repair and advised me to buy another computer. It is important for me to note that they referred to my laptop as "Very Old," and . . .
Meu Problema
This device was so slow that it was inappropriate to use even as a time machine server. After I replaced the 5400 RPM HDD with an SSD there was a noticeable improvement.
Minha Solução
The repair went smoothly after I reviewed the guide several times.
Meu Conselho
Place a piece of tape on the bottom of the case situated to help . . .
Meu Problema
I had a total hard drive failure.
Minha Solução
With the Ifixit step by step instructions, and the proper tools, replacing the hard drive was easy. Without the tools and instructions, I would have damaged something. Taking my time, the job took about 45 minutes.
Meu Conselho
Just follow the directions step by step. Get a jew . . .
Meu Problema
Battery goes to 0% from 20%
Minha Solução
Not successful. Screws turned out to be non-standard. iFixit tools did not fit in screw heads. I ordered torque screw drivers from iFixit and one other vendor. Neither fit. No worthwhile paying $100 for a store to repair as that would be about 20% of a new phone. I h . . .
Meu Problema
I wanted to replace the original 5400 rpm 1GB drive with a Samsung EVO 850 500GB SSD
Minha Solução
The drive swap actually ended up being easier than I thought. Reattaching the WiFi connector to the logic was the part that took me the longest. Those connectors always get me :)
Meu Conselho
Watch the video and take it slow.
Meu Problema
bad drive -- replaced with SSD
Minha Solução
Great the tapes make attachment of the screen easy.
Meu Conselho
take your time. Be sure to order the whole kit (with knife) each time as the place can get dull. Dull blades cause accidents.
Mostrar mais
