Professional 56 Driver Set
  • Professional 56 Driver Set
Não está à venda
Não está à venda
Não está à venda
kits de reparo de baterias de iPhone
Only $29.99
Buy Now
Only $29.99
Buy Now
Detalhes do produto
Descrição
Descrição
The end-all, totally comprehensive screwdriver set.
  • Each driver is ESD safe and built with a solid metal shaft, ergonomic plastic handle, and rotating top for easy use.
  • A complete set of fixed drivers for common screw sizes and interchangeable bits for the more obscure screw heads.
  • Packaged in an attractive wooden case with soft molded interior.
Set includes:
  • Slotted .025", .040", .055", .070", .080", .100", .125", .141", .156"
  • Phillips #000, #00, #0, #1
  • JIS-type S #0, #1
  • Hex .028", .035", .050"/#4, .062"/#6, .078"/#8, .093"
  • Metric Hex 0.7mm, 0.9mm, 1.3mm, 1.5mm, 2.0mm, 2.5mm
  • Torx® T-1, T-2, T-3, T-4, T-5, T-15, TP-8, TP-10
  • Nut Driver 5/64", 3/32", 7/64", 1/8", 5/32"
  • Metric Nut Driver 2.0mm, 2.5mm, 3.0mm, 3.5mm, 4.0mm
