Phillips #2 Screwdriver
  • Phillips #2 Screwdriver
US$2,99
US$2,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
Detalhes do produto
Descrição
Descrição
Unless you require a #2 Phillips driver for a deeply recessed screw, we recommend purchasing our 6-in-1-Screwdriver, which includes a Phillips #2 driver.
Histórias de Reparos
Avatar do usuário
Meu Problema
Computer was constantly running fans with little to no actual load. Upon closer investigation the computer was getting as high as 90 degrees Celsius when doing moderately demanding tasks.
Minha Solução
Opened the case and saw a bunch of dust everywhere. After the dust was removed the real problem revealed itself. . . .
Avatar do usuário
Meu Problema
Replaced built in optical drive with 250GB SSD drive. System was running really slow.
Minha Solução
It went well. Followed instructions and was pretty straight forward. Ran into a few hurdles....The screws can easily fall down into the case, which was very annoying. There is also a cable that has a very sensitive . . .
Avatar do usuário
Meu Problema
No facilities available in Australia, apparently.
Minha Solução
Quite ok. Thanx for online instructions.
Meu Conselho
Spludger
invaluable.l
Avatar do usuário
Meu Problema
My iMac 27 Inch i5 always frozen...
Minha Solução
Very well, I managed to happily. It 'just install "Fan control" fan set at maximum speed and the problem is solved!. For an excess of zeal, oh then apart my iMac 27 to carry out additional cleaning.
Meu Conselho
No, nothing special
Avatar do usuário
Meu Problema
The power supply of my Imac was broken
Minha Solução
My iMac is a 24" aluminum one, unfortunately there was no official guide on the website. However, there was a guide for changing the power supply in a 20" iMac, so I used that. There was also a video of the friendly lady, who made the repair look very easy. I al . . .
Mostrar mais
