Phillips #0 Screwdriver
  • Phillips #0 Screwdriver
  • Phillips #0 Screwdriver / iFixit - Made in Germany
  • Phillips #0 Screwdriver / Moody - Made in USA
US$6,99
US$6,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Detalhes do produto
Descrição
Descrição
Use this precision Phillips #0 screwdriver for electronics repair and DIY projects. The Phillips #0 screw is one of the most commonly used fasteners in consumer electronics, game consoles, laptops, PC desktop computers, and small home appliances. This particular size of Phillips screwdriver blade is also known as Phillips 0, PH 0, and PH #0.
The iFixit Phillips #0 screwdriver features a knurled grip and rubberized, ergonomic handle with swivel top. Made in Germany with uncompromising quality in manufacturing, this precision Phillips screwdriver is the last driver you'll ever need to buy. And to back that up, it's covered by iFixit's Lifetime Warranty.
Check the product option dropdown for the ESD-safe screwdriver made by Moody.
Histórias de Reparos
doshry's Story Photo #695092
Meu Problema
Had to upgrade my G4 Cube!
Minha Solução
Perfect! I feel like a brain surgeon!
Meu Conselho
Make sure you get the right tools and follow the right guides! I know a website :-p
Meu Problema
Needed battery for my Honda key fob
Minha Solução
This key fob requires the removal of an extremely small phillips screw to separate the key fob to access the battery; I had a couple of small screw drivers on hand and proceded with them but could not break the screw lose. I started rounding the phillip + out and t . . .
Meu Problema
I broke a headphone jack off in the Kindle
Minha Solução
A co-worker of mine actually did the repair. He said the step-by-step instructions and photos made this repair so easy.
Meu Conselho
Get the screwdriver, the tool to open the Kindle, the instructions and an extra set of hands. I opted to not separate the top from the bo . . .
Meu Problema
Music is my life. I've learned I can access it through my phone. To be polite to those around me, I use headphones and my phone's headphone jack.
One day, out of the blue, my phone only provided me with my fix through my right earbud. I cussed out the previous night's drunk me. I originally bla . . .
Meu Problema
Headphone jack connection became flaky. Typically only on channel would work (i.e. sound only out of left speaker)
Minha Solução
Followed "Samsung Galaxy S III Headphone Jack/Speaker Assembly Replacement" guide. Repair was very quick, cheap, and effective.
Meu Conselho
The #0 Phillips seemed a bit too big for the screws. It . . .
Meu Problema
Battery needed replaced
Minha Solução
Great
Meu Conselho
Everything went well following the guide.
Meu Problema
Dropped the phone and the speaker stopped working
Minha Solução
Success! The new speaker assembly works like new and I have sound again. I should have been more careful taking the back off because I knocked two clips off - it still fits back in place but has a small creak to it.
Meu Conselho
You DO NOT have to remove the batter . . .
Meu Problema
I was working at Starbucks when my friend Carlos saw me and came over to give me a hug. I knocked a whole bottle of Soylent on my keyboard. Eek.
Minha Solução
It took about two hours total. I was going extra slowly because I had not worked on a Macbook before. If I should need to do it again, god forbid, it could . . .
Meu Problema
A friend of mine has young children that were playing on their friends iPad and, after some elevated excitement, managed to drop the iPad. The bottom corner hit the ground and the digitizer shattered.
Minha Solução
The repair was initially difficult with the standard tools recommended. The plastic tools bend too e . . .
Meu Problema
it was headphone jack was beoke
Minha Solução
good
Meu Conselho
thanks
Mostrar mais
