P5 Pentalobe Screwdriver Retina MacBook Pro and Air
  • P5 Pentalobe Screwdriver Retina MacBook Pro and Air
  • P5 Pentalobe Screwdriver Retina MacBook Pro and Air / iFixit - Made in Germany / New
  • P5 Pentalobe Screwdriver Retina MacBook Pro and Air / Moody - Made in USA - ESD Safe / New
US$11,99
US$11,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Detalhes do produto
Descrição
Descrição
Use this precision P5 pentalobe screwdriver to open Retina MacBook and MacBook Air laptops. The P5 driver is compatible with the 5-point star shaped pentalobe 5IPR security fasteners used on the bottom of some Apple laptops.
This P5 pentalobe screwdriver from Moody Tools is made in USA and features an ESD safe handle with a swivel top, and a double ended reversible pentalobe tip.
Histórias de Reparos
Meu Problema
battery was dying and had "service battery" alert in notifications panel
Minha Solução
Went well except that the cord for the new battery was incrementally too short. It was able to plug in barely and on a slight angle, Hopefully this will be okay long-term; my concern is having to periodically open the assembly a . . .
Meu Problema
Needed more RAM memory to upgrade to High Sierra OS.
Minha Solução
Great.
Meu Conselho
Make sure you hav the correct RAM memory because there are various types.
Meu Problema
My MBP trackpad was broken. Needed the pentalobe screwdriver to open my laptop to replace the trackpad.
Minha Solução
Huge pain in the ass. On my model of macbook pro, you have to remove the batteries which are glued-in to get access to the track pad. I saw a guy on youtube use a metal scraper to do it, so I did t . . .
Meu Problema
Battery for Mac Air was dead. Ordered P5 Pentalobe Screwdriver and a battery on Ebay. Followed the directions on IFIXIT, which were excellent.
Minha Solução
Everything went without a hitch. Thank you!
Meu Conselho
Follow directions. Carefully unplug and reconnect battery.
Meu Problema
After five years the battery had cycled hundreds of times and was showing a need for service...
Minha Solução
The swap was quick and easy... less than 20 minutes... great repair guide and product.
Meu Conselho
ifixit.com should always be the first place you try.... great advice and solid products...
Meu Problema
Original Logic Board had failed
Minha Solução
Repair went without a hitch.
Meu Conselho
Follow the instructions!
Meu Problema
Trackpad kept drawing squares
Minha Solução
Good.
Meu Conselho
I used a T6 screwdriver instead of a T5 on step 10. Don't removed a metal plug that appears to be taped to the bottom underside of the trackpad.
Meu Problema
My laptop stopped being able to hold a charge. Left more than a minute unplugged the system would shutdown.
Minha Solução
Easier than I expected. Strangely only 4 screws were holding the case, either the others fell out or were left out by apple repair in the past.
Now the laptop can remain operational while un . . .
Meu Problema
My fan was making a weird noise. I didn't know if the fan motor was dying, or if some debris was the culprit. In either case, I needed to open up and have a look. Unfortunately, I didn't have the special pentalobe screwdrivers to open up my MacBook.
Minha Solução
My biggest problem was that I didn't even know whic . . .
Meu Problema
My sister accidentally dropped her Macbook Pro Retina after owning for more than 4 years. The warranty had expired a long time ago and the people at the Mac store gave an estimate of at least $700. When my family told me about this, I told them that was ridiculous and to order a new display from ifi . . .
Mostrar mais
