Metal Spudger
  • Metal Spudger
Metal Spudger
$2.99
$2.99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Detalhes do produto
Descrição
Descrição
For when you need that unyielding edge.
  • While our first-choice tool for poking and prying is always our trusty plastic spudger, sometimes you need a little more power behind your pry. In those instances, this metal spudger is the ideal tool for the job.
  • Features a comfortable, easy-grip handle and is great for prying up all sorts of tough components.
  • For the metal spudger fanatic, we also sell a set with an entire assortment of four different metal spudgers, for all of your hardcore spudgering needs.
Be sure to exercise caution when using this tool. With its great strength comes the potential to scratch or otherwise damage components that might be better served with plastic tools such as a spudger or plastic opening tool.
Vídeo do Produto
Histórias de Reparos
Gordon Krupsky's Story Photo #863027
Meu Problema
About a year ago, my left channel went almost dead. It was there, but so faint that you couldn't really hear it. I don't listen to my iPod through headphones too much, but I do use an FM transmitter in my car that gets audio via the headphone jack. In the car, instead of just having a dead left chan . . .
Meu Problema
Battery would not charge.
Minha Solução
Difficult to open the case, but was able to do it with patience, and without damaging the case.
Meu Conselho
Study the pictures in steps 21 and 23 to understand what the clips look like and the locations so that you know where and how to probe with the metal spudger to release the clips.
Meu Problema
Battery
Minha Solução
Awesome
Meu Conselho
Do not use them rip off kiosks at the mall. Do it yourself! It's very easy and way cheaper.
Meu Problema
Crack screen on a Verizon Surface 3, unusable in it's current state.
Minha Solução
Getting the old screen off was a pain. Lots of little pieces. Wish i would have known to just get one corner done and get to the meat of the screen. From there i could have possibly pulled it off faster with less shards!
Meu Conselho
Rated as a 1 . . .
Meu Problema
Won't boot up
Minha Solução
Order arrived in reasonable time & good condition. Prybars popped the case of Nexus 7 quickly & undamaged as advertised. Didn't find the quick & easy loose battery connection hoped for but tools were great. Will continue & possibly use other tools as time allows.
Meu Conselho
Best advice may be buy . . .
Meu Problema
Recently, I needed to replace the battery on my 6-year old Dell Adamo 13. I referred to the clearly written Dell Adamo 13 Teardown and clicked on the "Buy these tools" button to order all the recommended tools.
After receiving the tools, I realized that I still had no way to open the computer case . . .
Meu Problema
Front panel cassé!!
Minha Solução
Bien été mais il faut faire attention de pas trop chauffer avec le heat gun!! Regarder aussi le vidéo en plus des étapes!
Meu Conselho
Suivre les étapes et prendre sont temps!!
Meu Problema
broken display
Minha Solução
I bought the wrong display and I had no problem with the return. I got the right part and I followed the steps and had no problems. Thanks!
Meu Conselho
Follow the steps very easy!
Meu Problema
iPad was discharging quickly. Then it would not charge at all. Would not turn on or charge (dead). Determined the battery needed replaced.
Minha Solução
Used the iFixit guide and was able to successfully repair. I used a hair dryer to soften the adhesive and was very patient (heat, cautiously pry, heat and pry, . . .
Meu Problema
Accidentally our iPod classic fell unto the floor and consequently the harddisc was broken. The best solution seemed to be a replacement of the drive with a CF-card. If there is any pride, you go for it on your own and fix it.
Minha Solução
To start the opening process I found it easier to use a kitchen knife ins . . .
Mostrar mais
