Metal Spudger Set
  • Metal Spudger Set
  • Metal Spudger Set
Metal Spudger Set
US$7,99
US$7,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Detalhes do produto
Descrição
Descrição
Four times the brawn.
  • Any fixer knows that moment when you're stuck needing that one tool for the job—be prepared for the moment before it hits, with our assortment of four sturdy metal spudgers.
  • Easy-grip handles of just the right length for comfort and leverage.
  • Just the right amount of spring to pop out components and pry up against sticky adhesive.
Kit Contents:
  • Classic Metal Spudger - the tried and true original
  • Single Flat - with an extra long blade, great for iPad batteries
  • Small Pointed - reinforced and thick on both ends, good for scraping
  • Classic Wide - wide and slightly curved with rounded and pointed ends
  • Fitted Pouch - flexible plastic tool roll to keep your spudgers at the ready
Be sure to exercise caution when using these tools. With their great strength comes the potential to scratch or otherwise damage components that might be better served with plastic tools such as a spudger or plastic opening tool.
Histórias de Reparos
Meu Problema
the right side headphone jack didn't work
Minha Solução
Difficult but i did replace it in about 2 hours
Meu Conselho
just follow the instructions, they are great !
Meu Problema
Need to replace my existing battery pack. It got bulky and blocked my trackpad to function properly.
Minha Solução
The repair was great. Easy to follow instruction from ifixit was no hassle. Only took me 10-15 mins to fix my mac and works like a Pro.
Meu Conselho
Everything was perfect.
Meu Problema
Simple screen replacement. I watch videos and look at teardowns to prepare for those little things smartphones are so full of. I replaced the screen because it was cracked (bought it that way). No display but the soft-keys did light up.
Minha Solução
The repair went fine. I had to salvage the frame. Tedious work . . .
Meu Problema
I'm hard on phones and iPads. I can't even wear a watch. It ends up scratched, dented or in pieces within 6 months.
Minha Solução
It's the second time for the iPad mini digitizer so it was much easier. First time for the phone and that was simple too.
Meu Conselho
The one recommendation I have is read the step by step instruc . . .
Meu Problema
The WiFi on my wife's iPad 1 suddenly died. No Wifi signal and no access points showed at all. I researched the repair and found a possible solution on the iFixit website, so I decided to give it a try and order the WiFi/Charging port part. I also learned that the display clips frequently break w . . .
Meu Problema
iPad repair
Minha Solução
Got these just in time for my iPad repair. Made the job MUCH easier!
Meu Conselho
Not a must have,but very close.
Meu Problema
Lack of anger mgt. Threw s5 at wall, wall won!
Minha Solução
Way faster than I expected.
Meu Conselho
magnifying glasses and plenty of white light. Watch several videos there are several ways to skin a samsung, I used parts of all the ones I watched.
Meu Problema
I used the Jimmy and Metal Spudger Set to remove the Glass from a Samsung S3.
Minha Solução
unfortunately the Cracks in the glass where all the way through the LCD, the the tools worked great. The Jimmy as used almost exclusively.
Meu Conselho
Humm, well if your glass is very shattered take your time to get all the center glas . . .
Meu Problema
Wanted to speed up my iMac performance. The RAM was already maxed, so the only thing left to do was upgrade the what's drive to an SSD.
Minha Solução
It was pretty smooth. Much easier than I thought it would be.
Meu Conselho
I think it's worthwhile to upgrade the ram & SSD on your older Mac before going out and buying a new one . . .
Meu Problema
Friend needed new screen assembly replacement
Minha Solução
Followed the directions, warning stated " not for the faint of heart"!
So iread it over and over, it was dificult had a question ifixit answered within 15 minutes.
So pleased perfect results, so happy and productive and now i have some experience with one . . .
Mostrar mais
