Detailing Brush
  • Detailing Brush / Nylon
  • Detailing Brush / Brass
Detailing Brush
US$2,99
US$2,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
Detalhes do produto
Descrição
Descrição
No more worn out toothbrushes with bent bristles, these economic professional tools will do the job faster and better, fitting into more places, and don't require handle bending pressure to do a good job. These bristles are ready to scrub and clean with minimal effort.
This double ended brush will fit in tight spaces and quickly cleans up battery acid damage, residue from spills, corrosion from water damage, dust, and thermal paste residue.
Nota
This brush is safe for most applications, but is not an official "ESD safe" tool.
Histórias de Reparos
Avatar do usuário
Meu Problema
Water damage on a macbook pro.
There was a dime sized bit of corrosion on the logic board and it would not turn on.
Minha Solução
Pulled the back off, unhooked the battery, stogged the corroded bits with a really soft brush and alcohol. Let it dry, put it back together and it turned back on.
Meu Conselho
Be brave...
Avatar do usuário
Meu Problema
I am just starting out in the repair business, I repair all sorts of electronics, mainly the repairs are either Mobile Devices, Laptops, Computers. IFIXIT.com has a lot of the tools that are required for repairing these devices.
Minha Solução
Repairs go a lot quicker with the right tools.
Meu Conselho
Make sure you have the ri . . .
Avatar do usuário
Meu Problema
Bass from speakers just come out as muddled.
Minha Solução
Removed without much trouble.
Meu Conselho
The original screws securing the sub-woofer strips quit easily. Pay attention when removing them. I had to discard one screw I stripped. Luckily I could remove them by forcing the screwdriver into the screw to create new indent . . .
Avatar do usuário
Meu Problema
Silly Tri-Tip screwdrivers, lucky ifixit came to the rescue!
Minha Solução
Excellently
Meu Conselho
Make sure you order the right battery from Amazon, it's too bad that ifixit doesn't stock batteries for newer Macbook Pro's
Avatar do usuário
Meu Problema
Just needed some more tools for opening Apple Mac's, Getting out laptop screws that have had there heads destroyed and the magnetic project mat for the laptop screws.
Minha Solução
Always good
Meu Conselho
By the right tools for the right job and it always easier.
Mostrar mais
Quem comprou também levou
