iMac Intel 21.5" (2012-2017) Adhesive Strips
  • iMac Intel 21.5" (2012-2017) Adhesive Strips / Fix Kit
  • iMac Intel 21.5" (2012-2017) Adhesive Strips / Part Only
US$19,99
US$19,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Detalhes do produto
Descrição
Descrição
This complete set of replacement adhesive strips are specifically cut to fit 21.5" iMacs from Late 2012 through Mid 2017. The individual adhesive strips are labeled to indicate their correct location as shown in the replacement guides.
The unique design of the 21.5" iMac requires the replacement of the adhesive strips whenever the display assembly is removed. Fortunately, these adhesive strips are actually a foam tape, easily cut with an iMac Opening Wheel. Unfortunately, the display has to be removed every time anything needs to be replaced or upgraded inside the machine.
Compatibilidade
iMac Intel 21.5" EMC 2544
2.7 GHz (Late 2012)
2.9 GHz (Late 2012)
3.1 GHz (Late 2012)
iMac Intel 21.5" EMC 2545
3.3 GHz (Early 2013 Edu)
iMac Intel 21.5" EMC 2638
EMC 2638 2.7 GHz (Late 2013)
EMC 2742 2.9 GHz (Late 2013)
EMC 2742 3.1 GHz (Late 2013)
iMac Intel 21.5" EMC 2805
1.4 GHz (Mid 2014)
iMac Intel 21.5" EMC 2889
1.6 GHz (Late 2015)
2.8 GHz (Late 2015)
iMac Intel 21.5" EMC 3068
EMC 3068 non 4K 2.3 GHz
iMac Intel 21.5" Retina 4K Display (2015)
EMC 2833 3.1 GHz
EMC 2833 3.3 GHz
iMac Intel 21.5" Retina 4K Display (2017)
EMC 3069 3.0 GHz
EMC 3069 3.4 GHz
EMC 3069 3.6 GHz
Mostrar mais 5 dispositivos
Histórias de Reparos
JAMES WINSKOWSKI's Story Photo #1262296
JAMES WINSKOWSKI's Story Photo #1262297
Meu Problema
Bought the 4k Retina iMac from Best Buy for a great price, and didn't even thing about the fact that I was getting an HDD. Oh. My. Goodness. Tough to go back to HDD after getting used to flash/SSD storage. I ended up downgrading size from a 1TB HDD to a 525 GB SSD, but the speed is light years bette . . .
Masaki Fujimoto's Story Photo #1299543
Meu Problema
needed to replace hard disk drive to ssd.
Minha Solução
The strips were all partially peeled and I had a hard time to apply this to iMac. Some parts are even stretched or messed. However, I managed to apply all some how and did work in the end.
Meu Conselho
I'd love to see improvement on the product quality. Strips itself was g . . .
Meu Problema
Installed an SSD instead of the 6-year old HDD.
Minha Solução
Worked as intended. Seems like good stuff.
Meu Conselho
A friend recommended your site. Very grateful to him and to you guys.
Meu Problema
Just replacing Apple's slow standard 1TB SATA HDD with a new 500GB f-a-s-t SSD.
Minha Solução
Very well and smooth. Only issue was a minor misalignment of the display when re-assembling. Off just a tiny bit, but enough for the discerning eye at the right angle.
Meu Conselho
Go slowly...and do NOT apply any heat to remove the d . . .
Meu Problema
The stock 8 gigs is not enough under High Sierra for much more than email and browsing. Wanted to be able to run Virtual Machines of Windows 10 and some Linux distro
Minha Solução
I followed one user's advice and was able to exchange the memory without the full breakdown. I was able to loosen the motherboard scr . . .
Meu Problema
I replaced a regular HDD with an SSD.
Minha Solução
It went well for the most part. The pizza cutter tool didn't go quite deep enough to sever all of the adhesive. So I had to use a pick to go a little deeper. Not a big deal. My main issue was that the protective film on the adhesive strips weren't aligned properl . . .
Meu Problema
The spinning HDD side of the Fusion drive developed unrecoverable hard damage. Led to a surprising number of spinning beach balls.
Minha Solução
Straight forward. The wheel cut made screen removal quick.
Meu Conselho
Vacuum what dust you can during the job. Also, the HDD rubber boot completely fell apart. I just put the end . . .
Meu Problema
Aging iMac needed a caffeine shot. Maxed our memory and upgraded spinning disc with SSD. Like a brand new family computer again!
Minha Solução
Replaced the stock (x2) 4GB SO-DIMMS with (x2) 8GB, and 1TB spinning disc with a 512GB Crucial SSD. Offloaded bulk of iTunes library (400+GB by itself) to my NAS.
The proc . . .
Meu Problema
Upgrade drive with SSD Drive
Minha Solução
Perfect
Meu Conselho
Have Patience, take the time to do it
Meu Problema
Replaced the hard drive.
Minha Solução
Despite the lengthy instructions the job was actually much easier than the old iMac with the glass that was held in with magnets. The adhesive strip kit came with the cutting tool that makes the job very easy.
Meu Conselho
Definitely use the tape to hold the screen in place once you line i . . .
Mostrar mais
