MacBook and MacBook Pro Unibody Plastic Feet
  • MacBook and MacBook Pro Unibody Plastic Feet / Part Only
  • MacBook and MacBook Pro Unibody Plastic Feet / Fix Kit
US$4,99
US$4,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Detalhes do produto
Descrição
Descrição
Replace your Unibody's worn out feet with new plastic bumpers.
Includes one set of four new plastic feet.
Nota
These replacement feet do not fit Retina MacBook Pro models.
Compatibilidade
MacBook Pro 13" Unibody Early 2011
2.3 GHz
2.7 GHz
MacBook Pro 13" Unibody Late 2011
2.4 GHz
2.8 GHz
MacBook Pro 13" Unibody Mid 2009
2.26 GHz
2.53 GHz
MacBook Pro 13" Unibody Mid 2010
2.4 GHz
2.66 GHz
MacBook Pro 13" Unibody Mid 2012
2.5 GHz
2.9 GHz
MacBook Pro 15" Unibody Early 2011
2 GHz
2.2 GHz
2.3 GHz
MacBook Pro 15" Unibody Late 2008 and Early 2009
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
2.93 GHz
MacBook Pro 15" Unibody Late 2011
2.2 GHz
2.4 GHz
2.5 GHz
MacBook Pro 15" Unibody Mid 2010
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
MacBook Pro 15" Unibody Mid 2012
2.3 GHz
2.6 GHz
2.7 GHz
MacBook Pro 17" Unibody
2.66 GHz (Early 2009)
2.8 GHz (Mid 2009)
2.93 GHz (Early 2009)
3.06 GHz (Mid 2009)
MacBook Unibody Model A1278
2 GHz
2.4 GHz
Mostrar mais 9 dispositivos
Histórias de Reparos
Meu Problema
My old Macbook's battery was finally on its way out so I bought a new one from Ifixit.
Minha Solução
Not only did the battery show up sooner than I expected, the install was easy especially due to the the install guide they had available on their website. Now my laptops back to brand new (at least close to it.) . . .
Meu Problema
Missing plastic foot
Minha Solução
Went well
Meu Conselho
Nope
Meu Problema
The problem I had was my Macbook Pro 15" mid 2012 model lost the black rubber feet from the lower case. I went to apple and their solution was to sell me a complete lower case replacement for $199.99. REALLY!!!! ALL I NEEDED WAS FOUR BLACK 1" RUBBER DISKS.
Minha Solução
I contacted Fixit via the internet and purc . . .
Meu Problema
missing rubber feet
Minha Solução
Easy. Straightforward
Meu Conselho
Support this company. I hardly think replacing one missing rubber footing on my laptop is a $40 item. It's the principle of the thing, you know? I will always support a company that helps you find a way to fix your completely serviceable merchandise at a reaso . . .
Meu Problema
to provide better air flow under the case
Minha Solução
it was great straight forward no brainer
Meu Conselho
none
Meu Problema
After three years of using my MacBook Pro its pastic feet started to come off
Minha Solução
I ordered plastic feet for my MacBook Pro and couldn't be happier. Repair went just fine. Very pleasing was the fact that the feet went with their own adhesive material.
Meu Conselho
Highly recommended
Meu Problema
My old feet on my laptop were broken and falling apart..... from years of use?? 2012 laptop.
Minha Solução
Repair was fairly simple. I had to remove the bottom cover on the MacBook Pro. Poke out the feet that were still there (half broken). Clean the area to remove the old "sticky" stuff. Put the new ones on. Was . . .
Meu Problema
Missing one of the rubber feet; it fell off a long time ago and I couldn't find it.
Minha Solução
A snap. Literally. Snapped the replacement rubber foot, and done! I was even surprised to see that the rubber foot came with its own adhesive material. Gee, thanks!
Meu Conselho
Don't hesitate to try to fix it. I carried my MacBook . . .
Meu Problema
Feet Rotos
Minha Solução
Bastante fácil
Meu Conselho
Fecil
Meu Problema
My poor MacBook needed feet.
Minha Solução
I got the feet and with great ease put them on my MacBook
Meu Conselho
Don't be aggravated by a missing foot when they are so easy to get and replace
Mostrar mais
