Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
MacBook Upper Case Cable
  • MacBook Upper Case Cable / Silver
US$ 24,99
US$ 24,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Kits para o Nintendo Switch
Um reparo rápido para reiniciar o jogo
Confira kits para o Nintendo Switch
Detalhes do produto
Descrição
Descrição
Replace a damaged upper case cable and restore function to your upper case again. This cable transmits that data from the power button, keyboard, and trackpad to your MacBook's logic board.
Compatibilidade
Compatibilidade
  • All 13.3" MacBooks (excluding MacBook Unibody and MacBook Air)
Especificações
Especificações
Part #:
922-7991
Compatibilidade
MacBook Core 2 Duo
A1181 (EMC 2121) 1.83 GHz
A1181 (EMC 2121) 2 GHz (Late 2006)
A1181 (EMC 2121) 2 GHz (Mid 2007)
A1181 (EMC 2121) 2 GHz (Santa Rosa)
A1181 (EMC 2139) 2.16 GHz
A1181 (EMC 2200) 2.2 GHz (Santa Rosa)
A1181 (EMC 2242) 2.1 GHz (Penryn)
A1181 (EMC 2242) 2.4 GHz (Penryn)
A1181 (EMC 2300) 2 GHz (Early 2009)
A1181 (EMC 2330) 2.13 GHz (Mid 2009)
MacBook Core Duo
A1181 (EMC 2092) 1.83 GHz
A1181 (EMC 2092) 2 GHz
Histórias de Reparos
Avatar do usuário
paulxpac's Story Photo #230145
Meu Problema
My MacBook (Model 1181) is in pristine condition, so getting a new one seemed wasteful. After doing an internet search on possible causes of intermittent track pad and keyboard failure, I found it to be a consistent problem with these models. I ran thru the prescribe checks and decided to change out . . .
Avatar do usuário
lxtc's Story Photo #225913
Meu Problema
My upper case cable didn't like disassemblies much so I had to get a more cooperative one. / Excédé par des démontages intempestifs mon câble de clavier a décidé de cesser toute collaboration avec moi, d'où remplacement par un collègue au caractère plus docile.
Minha Solução
Thanks to the guide, all went . . .
Avatar do usuário
Meu Problema
bad, bad, bad cable
Minha Solução
The repair went awesome. Thanks iFixit!!!
Meu Conselho
Do what iFixit says.....
Avatar do usuário
Meu Problema
Trackpad and keyboard continuously seen as being disconnected and reconnected by USB daemon. Internet was unanimous that issue was USB upper case cable.
Minha Solução
Replaced the part (and replaced a few stripped screws too)... but issue persists. The problem : faulty upper ase cover.
Meu Conselho
When your mac starts going ha . . .
Avatar do usuário
Meu Problema
For some time I had problems with the computer recognizing my keyboard and touchpad and one day it just stopped turning on, so i opened the computer and i saw that the MacBook upper case cable was broken in one place probably because of many times of opening and closing the computer, 7 years old com . . .
Avatar do usuário
Meu Problema
Failed Logic Board. But in the process of removing the upper case to get to the logic board, the upper case cable connector fell to bits, but ifixit had one in stock.
Minha Solução
The repair went easy peasy with ifixit's guide, seriously. Not a screw left over.
Meu Conselho
Having the right tools makes all the difference.
Avatar do usuário
Meu Problema
I had opened up my MacBook to replace my optical drive with a SATA cable so that I could connect my external SATA drive internally and get the speeds that I need. After opening the case so many times, I guess the cable just broke. This being the case, my trackpad and internal keyboard no longer func . . .
Avatar do usuário
Meu Problema
I was upgrading a computer for a kid down the street. The original plan was to upgrade his hard drive and RAM. Once we accomplished that we decided to upgrade his OS as well. That's where the "scope creep" began. His DVD player was kapoot and we couldn't get the Snow Leopard DVD out of his machi . . .
Avatar do usuário
Meu Problema
I started out having to replace the Dvd drive as it was not working. I was putting everything back when I broke the keyboard ribbon cable.
Minha Solução
I used the ifixit repair guides and it went smoothly. They are fantastic! My MacBook is working fine with a brand new dvd superdrive. The keyboard and the b . . .
Avatar do usuário
Meu Problema
I couldn't start the laptop, so I had to fix it.
Minha Solução
It went perfectly, I've received the parts in just five days, by regular mail. Considering that I live in Spain. That was very fast.
Meu Conselho
Just be very careful with the Mackbook Upper case and it should go fine, and that in the other end of the cable(the on . . .
Mostrar mais
