MacBook Unibody (A1342 Late 2009-Mid 2010) Replacement Battery
  • MacBook Unibody (A1342 Late 2009-Mid 2010) Replacement Battery / New / Fix Kit
  • MacBook Unibody (A1342 Late 2009-Mid 2010) Replacement Battery / New / Part Only
  • 360°
360
US$84,99
US$84,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
PC Laptop Batteries
An easy fix for a big power boost.
Comprar agora
PC Laptop Batteries
Comprar agora
Detalhes do produto
Descrição
Descrição
This Replacement Battery compatible with MacBook Unibody (Model No. A1342 Late 2009/Mid 2010) is what you need to bring your laptop back back to life. Our aftermarket replacement batteries lead the industry in quality and reliability—each is tested and guaranteed to have a capacity greater than 5510 mAh—so you know you're getting the best money can buy.
Conteúdo do Kit
Conteúdo do Kit
Compatibilidade
Compatibilidade
  • MacBook 13" Unibody A1342 Late 2009 to Mid 2010
Especificações
Especificações
Part #:
661-5391
Model #:
A1331
Watt Hours:
63.5 Wh
Voltage:
10.95 V
Manufacturer:
Aftermarket
Compatibilidade
MacBook Unibody A1342
2.26 GHz
2.4 GHz
Histórias de Reparos
Avatar do usuário
nickmalmquist's Story Photo #1376790
Meu Problema
Battery life was less and less, and OSX said to replace soon. I also wanted to replace my original hard drive with an SSD.
Minha Solução
The two replacements were almost seamless. The first minor problem was that I did not get the tri-lobe screwdriver to remove the battery screws. I managed to get the job done wit . . .
Avatar do usuário
mmarkovich's Story Photo #504303
Meu Problema
Battery was out completely, swapped it out with a new iFixit battery.
Minha Solução
Once swapped the computer did not turn on. After a day of stress, found that the problem was the small connector left of where the battery plugs in. It had come loose slightly. With tape, nudged it back in to position. This is the . . .
Avatar do usuário
Meu Problema
Dead battery
Minha Solução
Went fine, was easy to replace...
Meu Conselho
if it needs replaced, don't hesitate, replace it
Avatar do usuário
Meu Problema
My wife's Macbook battery expanded, blowing out the trackpad and stretching the back cover. I guess it's $129 from apple to replace the battery, but we don't live near an apple store. I ordered the battery from IFIXIT and it was about $106 with tax. I searched other batteries on Amazon and other sto . . .
Avatar do usuário
Meu Problema
After upgrade to OS El Capitain, my macbook was too slow. On the same time, the battery was down for an intensive use during 6 years.
Minha Solução
Perfect!!! The battery was fitted and recognized by system and my macbook accept 8 gb of ram. The HD was ok and i used a software called "trim enabler" to activate T . . .
Avatar do usuário
Meu Problema
Dead battery on late 2009 Macbook (A1342).
Minha Solução
Replacement. Slightly more difficult than changing the batteries in your TV remote. Follow the instructions. They are very simple and to the point.
Meu Conselho
Use the right tools for the job! Buy the tool kit as it has everything you will need.
Plus, once untethere . . .
Avatar do usuário
Meu Problema
My partners late 2009 Macbook started to fall apart all at once. The rubberised bottom peeled off, the batter stopped holding a charge and the fan failed.
I replaced the laptop with a new macbook and kept the old one until it failed completely which was the day after it was replaced.
A year later . . .
Avatar do usuário
Meu Problema
Battery went bad
Minha Solução
ordered the correct part and was fixed in a minute
Meu Conselho
nope
Avatar do usuário
Meu Problema
battery was dead and magsafe board failed
Minha Solução
everything was great, i had 1 screw stripped from a previous repair but it wasn't too much of an issue and i broke 1 speaker connector , but that speaker was already blown and will be replaced once i can afford it.
Meu Conselho
be very gentle with the speaker connectors, t . . .
Avatar do usuário
Meu Problema
After 5 years, the battery simply couldn't keep working anymore. So it was time to replace it.
Minha Solução
It was an easy and clear unmounting, replacement and mounting. The battery is real easy to replace, just follow the steps carefully on the tutorial.
Meu Conselho
Careful on your tools! The tri-wing battery screw is reall . . .
Mostrar mais
