Fix Your Stuff
Right to Repair
Parts & Tools
MacBook Unibody (A1278) Hard Drive Cable
  • MacBook Unibody (A1278) Hard Drive Cable
  • 360°
360
US$ 39,99
US$ 39,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Detalhes do produto
Descrição
Descrição
Replace a broken or damaged hard drive cable compatible with a Model A1278 MacBook Unibody with this part.
This cable connects the hard drive to the logic board.
Compatibilidade
Compatibilidade
  • MacBook 13" Unibody A1278 2 GHz and 2.4 GHz
Especificações
Especificações
Part #:
922-8623
Compatibilidade
Histórias de Reparos
Avatar do usuário
Meu Problema
Macbook fell off the shoulder bag of my brother inlaw.
Booting from an external hd worked fine, so i figured it was either the cable or the hd. Since the hd was OK, cable was broken.
Minha Solução
Ordered in express the appropriate cable, opened the dusty beast (2008 Macbook), and fixed it. Took the opportunity t . . .
Avatar do usuário
Meu Problema
Replaced old platter drive with Samsung Evo 256gb SSD. Screen would show "no bootable device" during boot, even though I cloned the hdd to the ssd prior to installation. Read online about possible problems with the sata ribbon cable, so I decided to replace it.
Minha Solução
It was not easy getting the ribbon cab . . .
Avatar do usuário
Meu Problema
My MacBook stopped working with the harddrive. Tried everything, then i found an artikel that in most cases it is a problem with the Hard Drive Cable. And I found IFIXIT.
Minha Solução
First of all I ordered this cable from Denmark (Europe). To start with, I ordered a wrong cable witch I received after approx. 7-1 . . .
