MacBook Pro Heat Sinks
Grab a toolkit for your MacBook Pro model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Escolha seu modelo de MacBook Pro:
Peças compatíveis com MacBook Pro:
MacBook Pro 15" Retina (Mid 2012-Early 2013) Heat Sink
This part attaches to the processor and helps dissipate heat.
MacBook Pro 15" Retina (Late 2013-Mid 2015, Dual Graphics) Heat Sink
MacBook Pro 15" Retina (Late 2016-2019) Heat Sink
Replace a damaged heat sink compatible with a 2016 to 2019 model 15" MacBook Pro with Retina Display.
MacBook Pro 13" Unibody (Mid 2012) Heat Sink
Replace a bent or damaged heat sink compatible with a mid 2012 model 13" MacBook Pro Unibody laptop.
MacBook Pro 15" Retina (Mid 2018-2019) Heat Sink Brackets
Replace the metal spring brackets that press the heat sink against the CPU.
MacBook Pro 15" Unibody (Mid 2010) Heat Sink
Replace a damaged or missing heat sink in a Mid 2010 model Unibody 15" MacBook Pro. The heat sink dissipates heat from the CPU.
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Heat Sink
MacBook Pro 13" Retina (Late 2013-Early 2015) Heat Sink
Replace a damaged heat sink. This part dissipates heat generated by your computer's processors.
MacBook Pro 13" Unibody (Mid 2010) Heat Sink
MacBook Pro 15" Retina (Late 2013-Mid 2014, Integrated Graphics) Heat Sink
Informações do dispositivo
Catering to the working professional, the MacBook Pro is aptly named. With powerful processor and graphics capabilities, these Apple machines are great for either the professional or aspiring creative genius.
We sell dozens of MacBook Pro upgrades and repair parts. It's easy, fast, and safe to max out your machine! Two RAM slots allow for an easy memory boost. Need more storage? Drop in a larger-capacity 500 GB 7200 RPM 9.5mm SATA hard drive for some much-needed space as well as speed. An 85-watt MagSafe adapter will keep your machine juiced through even the most power demanding processes.
Select your version above for parts and assistance!
