MacBook Pro 17" (Model A1261) Keyboard
  • MacBook Pro 17" (Model A1261) Keyboard
US$89,99
US$89,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Kit de Reparo de Bateria do MacBook
A partir de $69.99
Buy Now
A partir de $69.99
Buy Now
Detalhes do produto
Descrição
Descrição
Replace a malfunctioning keyboard or one with missing keys. Compatible with a Model A1261 17" MacBook Pro.
Compatibilidade
Compatibilidade
  • MacBook Pro 17" A1261 Early 2008 and Late 2008
Especificações
Especificações
Part #:
922-8388
Compatibilidade
Histórias de Reparos
Avatar do usuário
Meu Problema
Spilled coffee on Macbook Pro keyboard.
Minha Solução
This old man got a little too frisky with his coffee cup near his Macbook Pro 17. Got it shut down and set it on its side for several hours hoping it would dry OK. Not to be, so used your Guide for this, which is VERY helpful, and tried to clean and dry the . . .
Avatar do usuário
Meu Problema
There were problems with the keyboard. Some keys such as 5,t,g, and b were unresponsive. After trying various methods to attempt to fix the problem, buying a new keyboard seemed to be the only solution.
Minha Solução
The repair went much better than expected. The keyboard and tools arrived very quickly after placi . . .
Avatar do usuário
Meu Problema
A can of Dr. Pepper was spilled and it seeped under the keyboard causing it to be sticky and unresponsive. I took out the keyboard and there was no way I would be able to clean it effectively.
Minha Solução
Repair went smoothly. The ribbon cables that were glued to the keyboard gave me a bit of trouble. I was afr . . .
