MacBook Pro 17" (Model A1151) Left Fan
  • MacBook Pro 17" (Model A1151) Left Fan
US$ 49,99
US$ 49,99
Detalhes do produto
Descrição
Descrição
An aging fan may become noisy and inefficient or simply fail and stop spinning, leaving your model A1151 17" MacBook Pro to overheat and eventually damaging your processors. Replace a defective fan to fix overheating problems or to keep your laptop running quietly.
Compatibilidade
Compatibilidade
  • MacBook Pro 17" A1151
Especificações
Especificações
Part #:
922-7510
Compatibilidade
MacBook Pro 17" Models A1151 A1212 A1229 and A1261
A1151 (EMC 2102) 2.16 GHz (Core Duo)
Histórias de Reparos
Avatar do usuário
Meu Problema
Our MacBook Pro had a noisy left fan.
Minha Solução
The repair is reasonably straightforward. The only difficult part is that I had to remove the left speaker enclosure to get at one of the Torx screws that holds the fan in place. From memory, the guide on iFixit for the fan replacement is written for the 15 inc . . .
Avatar do usuário
Meu Problema
Laptop had was making an awful racquet and determined that the left fan got out of balance.
Minha Solução
The repair went very smoothly. We found a Youtube video that showed all the hidden screw locations and special tools required. We easily took the laptop apart, installed the new fan, put it back together, and . . .
Avatar do usuário
Meu Problema
Noise from the left fan
Minha Solução
Smooth ;-)
Meu Conselho
Sooo easy ;-)
Avatar do usuário
Meu Problema
On my 17in Macbook Pro, I started having a lot of noise coming directly from my left fan. So I removed the left fan and made sure it was lubricated properly and then reinstalled. Unfortunately, this fix was only temporary...the fan quit working within a week.
Minha Solução
So I jumped on ifixit.com to order . . .
Avatar do usuário
Meu Problema
My old fan was so noisy it made working on my mac almost unbearable. A constant brbrbrbbrbrbrbrbbrb... It was time to start shopping for a new mac book or try and fix it. I'm so lucky I found ifixit.com!
Minha Solução
The repair was easy. I mean really easy - com'on it's just a couple of screws here and a piece of . . .
Avatar do usuário
court's Story Photo #153884
Meu Problema
The fan sounded like a Tardis and the laptop would overheat and ruin the battery.
Minha Solução
The repair went very well, thanks to clear instructions. I was even able to work on my giant space alien head the same evening.
Meu Conselho
I'm not sure my laptop is as good as new. Is something causing the laptop to overheat, push . . .
Mostrar mais
