Detalhes do produto
Descrição
This MacBook Pro 15" Unibody (Early 2011-Mid 2012) replacement battery is what you need to bring your dead laptop back to life!
- 100% factory tested.
- Tested and guaranteed to have no cycles on the cell and to have a capacity greater than 6730 mAh.
- Spot tested by iFixit staff in San Luis Obispo, CA to ensure consistency of quality and capacity.
- Assembled using a high quality chipset from Texas Instruments.
Battery degradation is an inevitable part of your laptop’s lifespan, extend it with this replacement battery compatible with Early 2011 to Mid 2012 MacBook Pro 15" Unibody. Factory-installed MacBook Pro batteries are rated to last 1,000 cycles. If your laptop won't turn on, turns off suddenly, has a "service battery" warning, or simply won't hold a charge, this replacement battery may be what you need to fix it. Our aftermarket replacement batteries lead the industry in quality and reliability, so you know you're getting the best money can buy.
Conteúdo do Kit
- MacBook Pro 15" Unibody (Early 2011-Mid 2012) Replacement Battery
- Spudger
- iFixit Precision Bit Driver
- Precision 4 mm Bits:
- Pentalobe P6
- Phillips #00
- Tri-point Y0
Compatibilidade
- MacBook Pro 15" Unibody A1286 Early 2011 to Mid 2012
Especificações
Compatibilidade
Avaliações de clientes
