Conserte seus objetos
Direito de executar reparos
Loja
MacBook Pro 15" (Models A1150/A1211) LCD Panel
  • MacBook Pro 15" (Models A1150/A1211) LCD Panel
  • 360°
360
US$ 199,99
US$ 199,99
Detalhes do produto
Descrição
Descrição
Replace a damaged or malfunctioning 15.4" 1440 x 900 LCD panel in your MacBook Pro 15" (Models A1150/A1211).
This LCD panel can restore dead pixels, fix color bleeding, and eliminate lines in your display image as well as restore a dim or dead backlight.
Compatibilidade
Compatibilidade
  • 1.83, 2 or 2.16 GHz (Model A1150) 15" MacBook Pros
  • 2.16 or 2.33 GHz (Model A1211) 15" MacBook Pros
Especificações
Especificações
Size:
15.4"
Resolution:
1440x900
Compatibilidade
MacBook Pro 15" Core 2 Duo Model A1211
A1211 (EMC 2120) 2.16 GHz
A1211 (EMC 2120) 2.33 GHz
MacBook Pro 15" Core Duo Model A1150
A1150 (EMC 2101) 1.83 GHz
A1150 (EMC 2101) 2 GHz
A1150 (EMC 2101) 2.16 GHz
Histórias de Reparos
Avatar do usuário
Meu Problema
My daughter accidentally crushed an LCD dead zone into her 15" Macbook Pro. Oopsy.
Minha Solução
Swimmingly, except for a couple of wobbly bits. Specifically, one corner anchor of the screen bezel refused to screw down and the camera cable didn't reattach properly.
Meu Conselho
Softening the glue with heat would have helped, an . . .
Avatar do usuário
Meu Problema
The screen was broken due to a hard hit on the upper case lid.
Minha Solução
The repair went very well and it worked right a way.
Meu Conselho
I just followed your DIY pictures and instructions online. Very good advice and easy to follow even though it is a difficult repair in general.
Avatar do usuário
Meu Problema
Left laptop in cold car and screen went bad. Tried to just replace inverter thing, but that wasn't it. Had to do the big LCD replacement.
Minha Solução
SMOOOOOOTH! ifixit is great! Got the part(s), the tools and clear, well-written, well-depicted directions and fixed my Macbook. It was weirdly fun and gratify . . .
Avatar do usuário
Meu Problema
My daughter's laptop LCD display got broke because my other daughter decided to through the remote and hit and broke the screen.
Minha Solução
The repair went without a hitch. I took it nice and slow. The only problem I had was with the spudger and using it to separate the pieces.
Meu Conselho
Get the spudger. It is good for k . . .
Avatar do usuário
Meu Problema
I drenched my old MBP with water, when I dropped a water bottle on it. I was getting it ready to ship to a buyer. After drying it out for three days, everything was fine except for the display.. It no longer functioned properly. I checked the inverter, it was fine, so determined it to be the dis . . .
Mostrar mais
