Conserte seus objetos
Direito de executar reparos
Loja
MacBook Pro 15" (Models A1150/A1211) Display Inverter
  • MacBook Pro 15" (Models A1150/A1211) Display Inverter
US$ 14,99
US$ 14,99
Detalhes do produto
Descrição
Descrição
There is no better time than now to repair a damaged Display Inverter!
Includes just the inverter board.
Compatibilidade
Compatibilidade
  • 1.83, 2 or 2.16 GHz (Model A1150) 15" MacBook Pros
  • 2.16 or 2.33 GHz (Model A1211) 15" MacBook Pros
Especificações
Especificações
Part #:
922-7191
Compatibilidade
MacBook Pro 15" Core 2 Duo Model A1211
A1211 (EMC 2120) 2.16 GHz
A1211 (EMC 2120) 2.33 GHz
MacBook Pro 15" Core Duo Model A1150
A1150 (EMC 2101) 1.83 GHz
A1150 (EMC 2101) 2 GHz
A1150 (EMC 2101) 2.16 GHz
Histórias de Reparos
Avatar do usuário
Meu Problema
The display in my MacBook Pro (Early 2006 - intel core duo) would work for a random amount of time after booting the machine and then flicker and go out. Seemed like the backlight was working but the inverter had failed.
Minha Solução
I received the inverter and followed the instructions. After putting everything . . .
Avatar do usuário
Meu Problema
The LCD backlighting died due to bad inverter.
Minha Solução
Great guide with the exception on the referenced Phillips head bit, PH00. I found that the J00 bit was a much better fit than the referenced PH00.
Meu Conselho
It's alive again ;-)I found that the J00 bit was a much better fit than the referenced PH00.
Avatar do usuário
Meu Problema
Screen on macbook pro was very dim. I could see the picture but the screen would not brighten. After reading some other forums I decided the display inverter was the problem.
Minha Solução
It was a pretty easy repair following all of the steps. It took about 45 mins to get the new part in and the machine put back . . .
Avatar do usuário
Meu Problema
My friend needed his laptop asap for a gig. Decided to start with the cheapest part first.
Minha Solução
Repair didn't go as plan. i suspected it needed more parts than just the inverter board. unfortunately replacement the inverter didn't fix the issue.
Meu Conselho
80% of the time first generation MacBook pro 15 Core2Duos u . . .
Avatar do usuário
Meu Problema
I could not see any images or my artwork after turning on my MacBook Pro 15. Also finding out that it would cost too much to repair at the place I have my mac fixed. So I searched online and found your website. After procrastinating for three months, I decided to get my MacBook Pro running again. F . . .
Avatar do usuário
Meu Problema
Cheaper than a repair
Minha Solução
It would have been easyer if I was under 70 years old!
It took about 2 hours.
Meu Conselho
I would advise not trying this unless, like me, you have spent the last ten years of your retirement building and repairing computers.
P.S. 45 years as a maintainence machinest.
Avatar do usuário
Meu Problema
The MacBook Pro was seriously thrashed. It was dropped and dented, the front bezel was broken at both lower side and held together with lots of tape, and the screen was falling apart and did not light up. There was a ghost image and I was able to connect a second screen and get the screen set to Mir . . .
Mostrar mais
