Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
MacBook Pro 15" (Model A1211) Left I/O Board
  • MacBook Pro 15" (Model A1211) Left I/O Board
  • 360°
360
US$ 34,99
US$ 34,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Kits para Nintendo Switch
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
Detalhes do produto
Descrição
Descrição
  • Replace a damaged or corroded I/O board for your model A1211 MacBook Pro 15" and fix problems with charging, audio, and data connections. This assembly includes the MagSafe power, USB, and audio ports.
  • Includes slots for internal Airport wireless card and PC Card ExpressCards.
Compatibilidade
Compatibilidade
  • MacBook Pro 15" A1211
Especificações
Especificações
Part #:
922-7911, 820-2055-A
Compatibilidade
Histórias de Reparos
Avatar do usuário
Meu Problema
Old Macbook Pro, no longer charging. I thought this laptop was consigned to the bin as the repair would have cost hundreds (at least that's what I thought!)
Minha Solução
It went surprisingly well and with very little collateral damage to other systems
Meu Conselho
1) Make sure you've got lots of space
2) Make sure that space i . . .
Avatar do usuário
Meu Problema
Working on my 2006 MBP , computer suddenly shut down, no warning of low battery, nothing. I immediately plugged in the charger, and noticed that the mag. plug did not / would not change to the orange charging state. I then checked the battery, ¾ charged. I managed to get the MBP laptop running . . .
Avatar do usuário
Meu Problema
A friend of mine dropped her macbook pro while it was charging and the magnet jack broke. She took it to an apple store to see about repairs, but out of warranty she was quoted 500$+ to repair it. She has 4 kids and is a single mom she could not afford the repairs or a new laptop, since I have exp . . .
Avatar do usuário
Meu Problema
Went to plug in the magsafe adapter into the MBP and got a juicy static electric discharge at the connector. Battery would not charge even though it continued to work off the power it was supplying. Tried another battery and had the same problem. My fear was correct in assuming the Left i/o board wa . . .
Avatar do usuário
Meu Problema
IO Board broke because pB dropped on the magsafe plug ;; ripped the connecters of the IO Board & blew some circuit.
Minha Solução
Part arrived before promised ship date; with the on-line guide replaced the board; reset PRAM and SMC and all is fine again. Very smooth dealing with Ifixit ... kudos' !!
Meu Conselho
no as difficult . . .
Avatar do usuário
Meu Problema
For years I've had a chronic problem with battery charging on a MacBook Pro. The laptop would indicate significant battery life remaining, yet discharge too rapidly and at some point abruptly crash as though all power was removed. Eventually, the battery would not charge at all and the laptop would . . .
Avatar do usuário
Meu Problema
My computer was not charging. The power cord would short out due to a bad connection at the Left I/O Board. The cause of the problem started years ago when my daughter decided to chew on the end of the power cord causing corrosion and subsequently shorting between the power cord and Left I/O Board c . . .
Mostrar mais
