MacBook Pro 15" (Model A1150) Left Fan
  • MacBook Pro 15" (Model A1150) Left Fan
US$ 29,99
US$ 29,99
Detalhes do produto
Descrição
Descrição
An aging left fan may become noisy and inefficient or simply fail and stop spinning, leaving your MacBook Pro 15" (Model A1150) to overheat and eventually damaging your processors. Replace a defective fan to fix overheating problems or to keep your laptop running quietly.
Compatibilidade
Compatibilidade
  • MacBook Pro 15" A1150
Especificações
Especificações
Part #:
922-7193
Compatibilidade
MacBook Pro 15" Core Duo Model A1150
A1150 (EMC 2101) 1.83 GHz
A1150 (EMC 2101) 2 GHz
A1150 (EMC 2101) 2.16 GHz
Histórias de Reparos
Avatar do usuário
Meu Problema
The left fan started making noise constantly.
Minha Solução
The repair went pretty smoothly. One of the metal tabs on the case broke off so that case screw couldn't go back in and another case screw just wouldn't go back without stripping. Also, took several tries to get the top back on the case. The tabs just . . .
Avatar do usuário
Meu Problema
The computer was overheating and began making a noise.
Minha Solução
The repair went excellently. To be honest this wasn't the first time I had had to perform surgery on this Macbook. A few years ago I had replaced the hard drive so I was already familiar with disassembling the computer and had the correct tools.
Meu Conselho
T . . .
Avatar do usuário
Meu Problema
The fan died.
Minha Solução
Excellent! The photo tutorial walked me thru the process and I had no issues.
Meu Conselho
Keep doing what you're doing, I'll be back when I have to make my next repair.
Avatar do usuário
Meu Problema
the fan began to make so much noise, i installed the software smcfan to saw whats was going on and i realized the left fan was dead 0 rpm
Minha Solução
perfect, i printed the guide and step by step i changed the fan, so easy
Meu Conselho
Only be carefull by pulling the plugs, better use the Spudger if you can.
When remove the . . .
Avatar do usuário
Meu Problema
The fan in my Macbook pro was creating a lot of noise. I needed to replace it.
Minha Solução
It went well. It was a little scary but I was successful.
Meu Conselho
Step 12 of the instructions was not as specific as I would have liked. I ultimately figured out how to do it but I was worried that I might be causing harm to my sys . . .
Avatar do usuário
Meu Problema
I replace my optical drive with a SSD.
Minha Solução
The installation was easy, no problem.
But when I install the OS on the SSD and boot from it, I can no longer enter sleep mode. I've tried to google the problem but have found nothing about that kind of behaviour. Anyone got a suggestion?
Meu Conselho
Nope, installation was . . .
Avatar do usuário
Meu Problema
A customer left a Macbook Pro with a faulty left fan. I went to ifixit.com for ordering not for being the cheapest on the market but for ideological reasons. Help the ones helping me!
Minha Solução
Did work great then checking the super guide at ifixit.com
Meu Conselho
Take it easy with Apple brand parts.
Avatar do usuário
Meu Problema
My right fan was dead, never showed as running when I checked istat pro. Led to my mac running hotter than it should. Figured I would replace both since I already had to open it for the one.
Minha Solução
The only complaint was UPS delivered my fans a day late when I paid for next day air. The only difficult part . . .
Avatar do usuário
Meu Problema
My old fellow (A MBP 2006) started to be noisy. The left fan was making a sound like a blender at top speed.
Minha Solução
The guide was incredibly helpful, the problems start when I tried to open the upper case, I broke some parts of it (Where you put the screws). Then I realized that some tapes where put on pla . . .
Avatar do usuário
Meu Problema
Damaged and noisy fan.
Minha Solução
It took about 45 minutes. The guide was very helpful. It was kind of hard taking the keyboard on and off, but I am pretty dumb when it comes to computers. I damaged a piece putting the keyboard back on, but it doesn't affect the performance of my computer. After replacing the f . . .
Mostrar mais
