MacBook Pro 15" (Late 2008-Mid 2012 excluding Mid 2009 2.53 GHz) Left Fan
  • MacBook Pro 15" (Late 2008-Mid 2012 excluding Mid 2009 2.53 GHz) Left Fan
US$59,99
US$59,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
Detalhes do produto
Descrição
Descrição
Replace the left fan for your Late 2008 through Mid 2012 Unibody 15" MacBook Pro (excluding Mid 2009 2.53 GHz) with this part. This part includes the fan and its surrounding metal bracket.
Compatibilidade
MacBook Pro 15" Unibody Early 2011
2 GHz
2.2 GHz
2.3 GHz
MacBook Pro 15" Unibody Late 2008 and Early 2009
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
2.93 GHz
MacBook Pro 15" Unibody Late 2011
2.2 GHz
2.4 GHz
2.5 GHz
MacBook Pro 15" Unibody Mid 2009
2.66 GHz
2.8 GHz
3.06 GHz
MacBook Pro 15" Unibody Mid 2010
2.4 GHz
2.53 GHz
2.66 GHz
2.8 GHz
MacBook Pro 15" Unibody Mid 2012
2.3 GHz
2.6 GHz
2.7 GHz
Mostrar mais 3 dispositivos
Histórias de Reparos
Avatar do usuário
Meu Problema
The left fan was making noise.
Minha Solução
Repair went smooth, easy to remove and install the new fan.
Meu Conselho
Be careful, screws are really small, pay attention to what length screw goes in each location.
Avatar do usuário
Meu Problema
Fan was making horrible noise at times.
Minha Solução
Repair was really simple. Basically remove the bottom plate to get inside the computer then removed 3 screws holding the fan in place. Used a plastic pry tool to gently disconnect the fan from connector and put the new one in, in a flash.
Meu Conselho
Just make sure you hav . . .
Avatar do usuário
Meu Problema
Left fan on a MacBook Pro - was very noisy
Minha Solução
Perfect /easy - iFixit instructions were fantastic.
Meu Conselho
Check the iFixit list before you just click on the tools they recommend - they should also recommend an anti-static wrist loop. Also use an egg box or daily/weekly pill dispenser to keep all the little scre . . .
Avatar do usuário
Meu Problema
Left fan runs / stops randomly, and makes big noise!
Minha Solução
Easy to replace within 10 min.
Meu Conselho
To browse infixit instruction before fixing it. It is hopeful!
Avatar do usuário
Meu Problema
Had to change the battery in my 5 year old MacBook Pro 15"
Minha Solução
The service and delivery speed was top notch!
Installed the new battery I got from Ifixit.
What bothers me is that the new battery is not as good as I expected.
It drains fairly quickly, almost the same speed as the old one.
The situation i . . .
Avatar do usuário
Meu Problema
The fans on my MacbookPro had been running constantly due to some software that seemed to need 1 CPU to run constantly to check web pages. After finally figuring out which software to trash and reducing use of the fan, the wear and tear of this bad software took its toll and eventually the fans sta . . .
Avatar do usuário
Meu Problema
My brother's Macbook Pro was making some interesting sounds on top of overheating. We did some research and came across ifixit.com how-to articles. From there, I ordered the fans (used), and the problem was fixed!
Minha Solução
Removing and replacing the right and left fans (Macbook Pro 15 mid-2009 2.8 GHz model) . . .
Avatar do usuário
Meu Problema
fans started making grinding noise so had to replace
Minha Solução
No problems. Easy and didn't take long
Meu Conselho
Make sure to clean out the intake grills before you switch up your fans, and it's probably a good idea to start cleaning out that dust every 6 months or so
Avatar do usuário
Meu Problema
Mis ventiladores hacían muchísimo ruido, ni se iba con lubricante especial para ventiladores.
Minha Solução
Ventiladores como nuevo. Silencio absoluto. Paquete bien protegido. Atención, servicio y rapidez de entrega inmejorable.
Valoración 12 sobre 10.
Meu Conselho
Lamento que en su página en Europa, no tengan existencias, . . .
Avatar do usuário
Meu Problema
leftFAN noises and damaged
rightFAN was ok but i want to change it
Minha Solução
All perfect, except for the rightFAN. I can't unscrew the old one, the screw is locked!
Meu Conselho
nn
Mostrar mais
