Peças Mac MacBook Pro 15" Unibody Mid 2012 Display Components
Loja
Grab a MacBook Pro 15" Unibody Mid 2012 Fix Kit and bring your laptop back to life!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Não sabe qual é o seu modelo? Identifique seu Mac
MacBook and MacBook Pro Unibody Plastic Feet / Part Only
Replace the black plastic feet on the lower case of your Unibody MacBook or MacBook Pro.
De US$ 4,99
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
US$ 8,99
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Replacement Battery / New / Fix Kit
Replacement battery, compatible with all Early 2011, Late 2011, and Mid 2012 15" Unibody MacBook Pros.
De US$ 89,99
Macbook Pro Unibody Lower Case Screw Set / Part Only
Replace a stripped or missing screw securing the lower case of most Unibody model MacBook Pro laptops. The excluded models are the Late 2008 and Early 2009 15" MacBook Pr...
De US$ 9,99
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
De US$ 89,99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
US$ 7,99
PC3L-12800 8 GB RAM Chip
RAM / 8 GB / PC3L-12800 / Low Profile / 204 pin, 1600 MHz
De US$ 49,99
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board
Replace a damaged or malfunctioning magnetic DC power connector.
De US$ 14,99
MacBook Pro 15" Unibody (Mid 2009-Mid 2012) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard and internal power button switch compatible with a Unibody A1286 15" MacBook Pro from mid 2009 to mid 2012.
US$ 19,99
PC3L-12800 4 GB RAM Chip
RAM / 4 GB / PC3L-12800 / Low Profile / 204 pin, 1600 MHz
US$ 29,99
Mostrando produtos 1 - 10 de 52
Informações do dispositivo
The Mid 2012 version of MacBook Pro 15" Unibody is virtually identical to the Late 2011 model with a CPU and graphics upgrade. It features an Ivy Bridge quad core Core i7 processor with PC3-10600 RAM. In addition to the Thunderbolt port and SDXC card slot it now features two USB 3 ports.
The most common repairs with Mid 2012 model MacBook Pro 15" Unibody laptops are replacing a dead battery, replacing a malfunctioning left or right fan, and upgrading the hard drive or RAM. The MacBook Pro 15" Unibody (Mid 2012) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 16 GB of RAM.
The Mid 2012 model MacBook Pro 15" Unibody requires a Tri-point Y0 Screwdriver to remove the battery. Our battery repair kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Unibody Mid 2012 repair guides for step-by-step instructions on how to make the fix.
