MacBook Pro 15" Touch Bar Mid 2017 Heat Sinks
Grab a toolkit for your MacBook Pro 15" Touch Bar Mid 2017 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Peças compatíveis com MacBook Pro 15" Touch Bar Mid 2017:
MacBook Pro 15" Retina (Late 2016-2017) Heat Sink Brackets
Replace the metal spring brackets that press the heat sink against the CPU.
MacBook Pro 15" Retina (Late 2016-2019) Heat Sink
Replace a damaged heat sink compatible with a 2016 to 2019 model 15" MacBook Pro with Retina Display.
Informações do dispositivo
Released in June 2017 as model A1707, this MacBook Pro features Kaby Lake processors up to the 2.9GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.9GHz.
The most common repairs with the 15" MacBook Pro Retina Mid 2017 laptops are replacing a dead battery, replacing a malfunctioning left or right fan, or a damaged display assembly.
The battery in a MacBook Pro 15" Retina Mid 2017 is adhered to the inside of the upper case. Our replacement batteries include the needed adhesive.
The MacBook Pro 15" Mid 2017 models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Retina Display Mid 2017 repair guides for step-by-step instructions on how to make the fix.
