Peças Mac MacBook Pro 15" Touch Bar 2019 Rubber Feet
Loja
Não sabe qual é o seu modelo? Identifique seu Mac
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
US$8,99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
US$7,99
MacBook Pro 15" Retina (Late 2016-2019) Display Assembly / A-Stock / Dark Gray
Replace a scratched, cracked, or malfunctioning diplay assembly for your 2016 to 2019 model 15" MacBook Pro with Retina Display. This assembly includes the Retina LCD scr...
US$599,99
MacBook Pro 15" Retina (Late 2016-2019) Left Speaker
Replace a damaged or malfunctioning speaker compatible with a Late 2016 to 2019 model MacBook Pro 15" with Touch Bar.
De US$14,99
MacBook Pro 15" Retina (Late 2016-2019) Right Speaker / New
De US$14,99
MacBook Pro 15" Retina (Late 2016-2019) Display Cable
Replace the short flex cable that connects the display daughter board to the logic board.
De US$19,99
MacBook Pro Retina (A1989 & A1990 Mid 2018-2019) USB-C Board
Replace one of the thunderbolt connector boards from the left or right side of your laptop.
US$34,99
MacBook Pro 15" Retina (Late 2016-2019) Antenna Bar
Replace a damaged or malfunctioning antenna bar compatible with a 2016 to 2019 model 15" MacBook Pro with Retina Display.
De US$24,99
MacBook Pro 15" Retina (Late 2016-2019) Lower Case / New / Dark Gray
Replace a scratched or dented lower case compatible with a 2016 to 2019 model 15" MacBook Pro with Retina Display.
De US$49,99
MacBook Pro 15" Retina (Late 2016-2019) Left Fan
Replace a defective or noisy fan compatible with a 2016 to 2019 model 15" MacBook Pro with Retina Display.
De US$49,99
Mostrando produtos 1 - 10 de 31
Informações do dispositivo
Introduced in May 2019 as model A1990, this MacBook Pro features Coffee Lake processors up to the 2.4 GHz Intel Core i9 processor with Turbo Boost up to 5.0 GHz.
The most common repairs with the 15" MacBook Pro Retina 2019 laptops are replacing a dead battery, replacing a malfunctioning left or right fan, or a damaged display assembly.
The battery in a MacBook Pro 15" Retina 2019 is adhered to the inside of the upper case. Our replacement batteries include the needed adhesive.
The MacBook Pro 15" 2019 models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Retina Display 2019 repair guides for step-by-step instructions on how to make the fix.
