MacBook Pro 15" Retina Mid 2015 Integrated Graphics Logic Boards
Grab a toolkit for your MacBook Pro 15" Retina Mid 2015 Integrated Graphics model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Peças compatíveis com MacBook Pro 15" Retina Mid 2015 Integrated Graphics:
MacBook Pro 15" Retina (Mid 2015, Integrated Graphics) 2.5 GHz 16 GB RAM Logic Board
Replace a 2.5 GHz Core i7 logic board (motherboard) compatible with the Mid 2015 Integrated Graphics model MacBook Pro 15" Retina laptop. Fix processing issues like unex...
MacBook Pro 15" Retina (Mid 2015, Integrated Graphics) 2.2 GHz 16 GB RAM Logic Board
Replace a 2.2 GHz Core i7 logic board (motherboard) compatible with the Mid 2015 Integrated Graphics model MacBook Pro 15" Retina laptop. Fix processing issues like unexp...
MacBook Pro 15" Retina (Mid 2015, Integrated Graphics) 2.8 GHz 16 GB RAM Logic Board
Replace a 2.8 GHz Core i7 logic board (motherboard) compatible with the Mid 2015 Integrated Graphics MacBook Pro 15" Retina laptop. Fix processing issues like unexpected ...
Informações do dispositivo
In May 2015 Apple introduced a new 15" MacBook Pro with Retina display that is externally identical to the "Mid 2014" model by dimensions, weight, and 2880x1800 display resolution. Internally, the Mid 2015 Integrated Graphics (IG) model has a single Iris Pro 5200 graphics processor. The Mid 2015 model has two USB 3.0 ports, an HDMI port, an SDXC card slot, a MagSafe 2 port, two Thunderbolt 2 ports, Bluetooth 4.0, and 802.11ac Wi-Fi. Like the 2013 and 2014 models the Mid 2015 does not have Ethernet or Firewire ports, although adapters are available.
The most common repairs with the 15" MacBook Pro Retina Mid 2015 laptops are replacing a dead battery, replacing a malfunctioning left or right fan, or a damaged display assembly.
The battery in a MacBook Pro 15" Retina Mid 2015 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 15" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Retina Display Mid 2015 repair guides for step-by-step instructions on how to make the fix.
