Peças Mac MacBook Pro 15" Retina Late 2013 Headphone Jacks
Loja
Não sabe qual é o seu modelo? Identifique seu Mac
MacBook Pro Retina (A1425, A1502, and A1398) Plastic Feet / Part Only
Replace missing or damaged black plastic feet on your laptop's lower case.
De US$4,99
MacBook Pro 15" Retina (Late 2013-Mid 2014) Battery / New / Fix Kit
Replacement 8440 mAh battery compatible with a MacBook Pro 15" Retina (Late 2013/Mid 2014) laptop.
De US$89,99
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
US$8,99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
US$7,99
OWC Aura Pro X2 SSD
OWC Aura Pro X2 SSD
Replace or upgrade the PCIe solid-state drive in a variety of Macs.
De US$149,99
MacBook Pro Retina (2012-2015) Lower Case Screw Set / Part Only
Replace a stripped or missing screw securing the lower case.
De US$19,99
MacBook Pro 15" Retina (Mid 2012-Mid 2015) Right Speaker
Replace a broken or damaged right speaker for your Mid 2012 to Mid 2015 MacBook Pro 15" Retina laptop with this part and fix sound issues.
US$29,99
MacBook Pro 15" Retina (Mid 2012-Mid 2014) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard compatible with a model A1398 15" MacBook Pro with Retina display from Mid 2012 to mid 2014.
US$19,99
MacBook Pro 15" Retina (Mid 2012-Mid 2015) Left Speaker
Replace a broken or damaged left speaker for your Mid 2012 to Mid 2015 MacBook Pro 15" Retina laptop with this part and fix sound issues.
US$29,99
Silicone 2.5" Hard Drive Enclosure with USB 2.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
US$9,99
Mostrando produtos 1 - 10 de 42
Informações do dispositivo
On October 22, 2013 Apple introduced a new 15" MacBook Pro with Retina display that is externally identical to the "Early 2013" model by dimensions, weight, and 2880x1800 display resolution. Internally, the Late 2013 model has a faster and more efficient processor architecture, entry level models have a single integrated graphics (IG) processor, and higher-end models offer a dual graphics (DG) processor. The Late 2013 model has two USB 3.0 ports, an HDMI port, an SDXC card slot, a MagSafe 2 port, two Thunderbolt 2 ports, Bluetooth 4.0, and 802.11ac Wi-Fi. Like the Early 2013 model the Late 2013 does not have Ethernet or Firewire ports, although adapters are available.
The most common repairs with the 15" MacBook Pro Retina Late 2013 laptops are replacing a dead battery, replacing a malfunctioning left or right fan, or a damaged display assembly.
The battery in a MacBook Pro 15" Retina Late 2013 is adhered to the inside of the upper case. Our battery repair kits include the needed adhesive.
The MacBook Pro 15" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs. Our battery kits include all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 15" Retina Display Late 2013 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 15" Retina Display Late 2013 earned a 1 out of 10 in iFixit's repairability assessment.
