MacBook Pro 13" Unibody LCD Panel
  • MacBook Pro 13" Unibody LCD Panel
Brand new glossy LCD.
US$69,99
US$69,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
Visite Nossa Loja
Ever fixed something? That’s Genius.
Share your repair story with #ImAGenius
We Are All Geniuses
Detalhes do produto
Descrição
Descrição
Replace a damaged or malfunctioning LCD panel for your 13" MacBook Unibody (all models except MacBook Air) or 13" MacBook Pro Unibody (all models) with this part.
If you are looking for an easier repair, you can also buy the full display assembly which contains all the display components. It's a much easier repair. Click your model below:
Nota
This part only includes LCD panel only, it does not include bezels, hinges, metal frame, cables, or iSight camera.
Compatibilidade
Histórias de Reparos
Avatar do usuário
Jay's Story Photo #999704
Meu Problema
The lcd panel was in need of replacement. ("lines")
Minha Solução
I followed the guide to remove the entire display assembly (screen/top part) so the repair went fine. It took me a lot longer than I thought because of a bit of struggle removing the glass but really because of the plastic clutch cover! I hate havin . . .
Avatar do usuário
Meu Problema
To extend life of my pro
Minha Solução
Easy
Meu Conselho
Follow the directions and the go slowly
Avatar do usuário
Meu Problema
My cat walked on my Mac-book and it crashed on the floor.
The screen broke in the meddle and the Apple store didn't want to repair it because too old (for them).
Minha Solução
I fixed it easily following the photo-sequence of iFixit web site,
However I suggest two improvements:
1. It's not necessary to use the Hea . . .
Avatar do usuário
Meu Problema
old lcd display was broken.frontglass was ok,so i just wanted to change the lcd panel.
Minha Solução
i used the ifixit guide for lsd panel change.used heatgun on lowest setting to get the glas out with a 0.7mm thick guitar pick.the guitar pick was a real good advise in the rep guide.I also drilled holes under the . . .
Avatar do usuário
Meu Problema
A fist-sized black hole was left in the upper center of the LCD display after an adjustable halogen lamp decided to take a nap on the upper edge of my open laptop while I was preparing dinner.
Minha Solução
My husband and I replaced the panel over a three day period. He removed the various screws and parts while I . . .
Avatar do usuário
Meu Problema
My screen kept fading to white on my Mac unibody notebook (A1342). It would work if I put pressure on the side of the screen, but it got old holding the screen anytime I wanted to use my computer.
Minha Solução
I replaced the LCD with the antiglare screen (IF163-02404) and it works, sort of.
I no longer have to . . .
Avatar do usuário
Meu Problema
The screen on my Macbook was cracked really bad.
Minha Solução
My son installed the screen with no problems and it looks just like new.
Meu Conselho
You can purchase with confidence this screen.
Avatar do usuário
Meu Problema
I received a free broken MacBook because the original owner understandably didn't want to pay over $300 to get the LCD screen fixed. So I did some research and it led me to ifixit. The price was right and the instructions looked fairly easy, so I gave it a try.
Minha Solução
This was the first time I have ever wor . . .
Avatar do usuário
Meu Problema
Broken LCD
Minha Solução
I just broke a Four wire connector in step Four or Five.. To replace the lcd wasnt a Big deal.. Now the MacBook runs again perfectly, just the Sdcard doesnt work.. i think because of the broken connector.. Thanks to IFixit to have my MacBook Pro back!,
Meu Conselho
Be careful to disconnect the differen . . .
Avatar do usuário
Meu Problema
Someone dropped the machine, only the upper right corner was broken, but important stuff sometimes appears there!
Minha Solução
Smooth enough. Yay iFixit. Glad you all get to retire now that Apple has bought your company (and very cool that you got them to agree to make the most repairable devices). You got me, to . . .
Mostrar mais
