MacBook Pro 13" Unibody (Early 2011-Mid 2012) SATA SuperDrive Cable
  • MacBook Pro 13" Unibody (Early 2011-Mid 2012) SATA SuperDrive Cable
Condição: Usado
US$19,99
US$19,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Detalhes do produto
Descrição
Descrição
SuperDrive feeling disconnected?
Reconnect your SATA SuperDrive with our SuperDrive cable!
Note: this cable is for SATA optical drives only. If you do not have a 13" Unibody MacBook Pro, this part will not work in your machine.
Histórias de Reparos
Meu Problema
I was having intermittent connection issues on SATA 1+2 ports.
Minha Solução
The repair went off without a hitch. I replaced both the superdrive cable and the HDD cable.
Meu Conselho
If you are having random hangs and kernel panics on heavy I/O with this MacBook Pro model (mid 2012), this is the fix if the HDD or SSD are known . . .
