Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Parts Mac MacBook Pro MacBook Pro 13" MacBook Pro 13" Unibody MacBook Pro 13" Unibody Mid 2009 USB Boards
Loja
Grab a toolkit for your MacBook Pro 13" Unibody Mid 2009 model and bring your laptop back to life!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Não sabe qual é o seu modelo? Identifique seu Mac
MacBook Pro 13" Unibody (Mid 2009-Mid 2012) Replacement Battery / Fix Kit
Replace a 5800 mAh battery compatible with MacBook Pro 13" Unibody (Mid 2009 to Mid 2012). 63.5 Watt Hours (Wh), 10.95 Volts (V).
De US$ 94,99
MacBook and MacBook Pro Unibody Plastic Feet / Part Only
Replace the black plastic feet on the lower case of your Unibody MacBook or MacBook Pro.
De US$ 4,99
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
US$ 8,99
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
De US$ 89,99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
US$ 7,99
MacBook Pro Unibody Lower Case Screw Set / Part Only
Replace a stripped or missing screw securing the lower case of most Unibody model MacBook Pro laptops. The excluded models are the Late 2008 and Early 2009 15" MacBook Pr...
De US$ 9,99
Universal Drive Adapter
Turn your current hard drive into an external drive with this part.
US$ 24,99
MacBook Pro Unibody (A1278) Keyboard
Replace a damaged, dirty, corroded, or malfunctioning keyboard and power button switch compatible with a mid 2009 to mid 2012 A1278 model 13" MacBook Pro Unibody laptop.
US$ 19,99
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board / New
Replace a damaged or malfunctioning magnetic DC power connector.
De US$ 14,99
MacBook Pro 13" Unibody and MacBook 13" Unibody Fan / Used / Silver
Replace a malfunctioning or noisy fan compatible with several models of 13" MacBook and MacBook Pro Unibody laptops.
US$ 19,99
Mostrando produtos 1 - 10 de 44
Informações sobre os dispositivos
With the Mid 2009 model 13 inch MacBook Pro Unibody laptop, Apple brought back the Firewire 800 port, added an SD card slot, and increased the processor speed.
The most common repairs with the MacBook Pro 13" Unibody for Mid 2009 are replacing a dead battery or upgrading the hard drive or RAM. The MacBook Pro 13" Unibody (Mid 2009) Memory Maxxer RAM Upgrade Kit includes all the parts and tools you need to upgrade to 8 GB of RAM.
The MacBook Pro 13" Unibody for Mid 2009 requires a Tri-point Y0 Screwdriver to remove the battery. The battery kit includes all the needed tools.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Unibody for Mid 2009 repair guides for step-by-step instructions on how to make the fix.
