Parts Mac MacBook Pro MacBook Pro 13" MacBook Pro 13" Retina MacBook Pro 13" Touch Bar Mid 2017 Case Components
Loja
Grab a toolkit for your MacBook Pro 13" Touch Bar Mid 2017 model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Não sabe qual é o seu modelo? Identifique seu Mac
MacBook Pro 13" (A1706, A1708, A1989, A2159) Trackpad / New / Silver
Replace a scratched or malfunctioning trackpad compatible with a model A1706, A1708, A1989, or A2159 MacBook Pro 13" with Retina Display.
A partir de US$ 49,99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Upper Case / A-Stock / Silver
Replace an upper case, keyboard, or touch bar compatible with the Late 2016 to Mid 2017 model 13" MacBook Pro Retina Touch Bar laptop.
US$ 169,99
MacBook Pro 13" Retina (Late 2016-2017) Display Gasket
Replace the elastic plastic gasket that fits around the outside edge of the display assembly for a Late 2016 or 2017 model 13" MacBook Pro with Retina Display.
US$ 9,99
MacBook Pro 13" Retina (A1706, A1989, A2251, A2289) Hinge Covers
Replace the plastic covers for the display hinges.
US$ 0,99
MacBook Pro 13" Retina (Late 2016-2020) Heat Sink Brackets
Replace the two metal spring brackets that press the heat sink against the CPU in a 2016 to 2020 model 13" MacBook Pro with Retina Display.
US$ 5,99
MacBook Pro 13" Retina (Late 2016-2020) Display Cable Brackets
Replace the brackets that secure the display cable connector to the display daughter board and clamp the middle of the cable to the upper case assembly in a 2016 to 2020 ...
US$ 4,99
MacBook Pro 13" Retina (Late 2016-2017) Display Hinge Spring
Replace a damaged spring tension hinge bracket compatible with a Late 2016 or 2017 model 13" MacBook Pro with Retina display.
US$ 9,99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2019) Lower Case / Silver / New
Replace a scratched or dented lower case compatible with a 2016 to 2019 model 13" MacBook Pro with Retina Display and Touch Bar.
US$ 49,99
MacBook Pro 13" Retina (Touch Bar, Late 2016-2017) Upper Case Assembly / A-Stock / Dark Gray
Replace an upper case, keyboard, touch bar, or battery compatible with the 2016 or 2017 model A1706 MacBook Pro 13" Retina Touch Bar laptop.
US$ 399,99
MacBook Pro 13" Retina (Late 2016-2020) Trackpad Cable Bracket
Replace a bent or missing metal bracket that secures the trackpad cable connector to the logic board compatible with 2016 to 2020 model 13 inch MacBook Pro laptops.
US$ 3,99
Exibindo produtos 1 - 10 de 13
Informações do dispositivo
Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz. Model A1706.
The most common repairs with the 13" 2017 model MacBook Pro with Retina Display and Touch Bar laptops are replacing a dead battery or a damaged display assembly.
The battery in a MacBook Pro 13" Retina and Touch Bar 2017 is adhered to the inside of the upper case. Our batteries include the needed adhesive.
The MacBook Pro 13" Retina Display models require a P5 Pentalobe Screwdriver to remove the lower case to begin any internal repairs.
Once you've bought your parts and tools, check out iFixit's MacBook Pro 13" Retina Display and Touch Bar 2017 repair guides for step-by-step instructions on how to make the fix.
The MacBook Pro 13" Retina Display and Touch Bar 2017 earned a 1 out of 10 in iFixit's repairability assessment.
