MacBook Fan
  • MacBook Fan
MacBook Fan
US$14,99
US$14,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Detalhes do produto
Descrição
Descrição
Replace a defective or noisy fan for your MacBook with this part. This part is compatible with all MacBook 13" models (excluding Santa Rosa, Penryn, and Unibody).
Compatibilidade
MacBook Core 2 Duo
1.83 GHz
2 GHz (Late 2006)
2 GHz (Mid 2007)
2.16 GHz
MacBook Core Duo
1.83 GHz
2 GHz
Histórias de Reparos
dezineworks's Story Photo #714075
Meu Problema
starting to fix some old favorite MacBooks around the house
Minha Solução
first iFixit project: replaced a fan in a 2006 MacBook 1,1 and a dead battery in the same 2006 MacBook. now i feel like i'm ready to learn how to replace the display. and upgrade the 350GB HD to 5400rpm or 7200rpm or 10000rpm 2TB HD or SSH . . .
Meu Problema
Fan not working, making a lot of noise, and laptop shutting down due to over heating.
Minha Solução
Thanks to the step by step guide, the repair was pretty simple and straight forward. Would never have known which screws to remove if not for the guide!
Meu Conselho
Just reiterating another user...print out the guide and tape th . . .
Meu Problema
Le ventilateur ne tournait quasi plus
Minha Solução
En suivant le guide, tout s'est super bien passé. Il faut juste être prudent avec toutes les vis minuscules en démontant et remontant la machine.
Meu Conselho
Prenez votre temps et assurez vous que votre tournevis est bien adapté à la taille des vis.
Meu Problema
The MacBook worked OK until anything like streaming a video shut it down.
It was obvious that overheating caused the temperature sensor to shut it down.
And there was no sound of the fan, so I ordered the fan to repair it.
Minha Solução
The repair went easily since I had been familiar with MacBook computers in t . . .
Meu Problema
Enorme bruit de ventilation
Minha Solução
Très bien
Meu Conselho
Prendre sont temps et avoir les bon outils
Meu Problema
For over a year, my 2007 MacBook has been overheating and displaying a black screen with a bunch of mumbo jumbo text, and all I could do was force shut down. It would not last a second trying to watch a youtube video. I found this site and the videos made it seem so easy to repair a fan. Since it wa . . .
Meu Problema
the fan was broken, very noisy like a lawn mower.
Minha Solução
i followed the guide : MacBook Core 2 Duo Fan Replacement.
Pretty easy, execpt the last part with the black felt tape, careful !
Meu Conselho
be careful with the black felt tape and take your time.
Meu Problema
2007 MacBook (original) fan was getting noisy and I was afraid of fan failure
Minha Solução
The repair went GREAT! Instructions were easy to follow, and though I was a bit nervous about opening my laptop I even got it all back together without any screws still in hand.
The new fan fan works flawlessly and my Ma . . .
Meu Problema
I have an old MacBook that lives in my server closet that provides three AppleTVs and all of our various iDevices with Video/Music. The fan was on its last leg and sounded like a monster was trying to escape the laptop with a hammer.
Minha Solução
Repair went flawlessly thanks to the great directions on iFixit.
Meu Conselho
Nop . . .
Meu Problema
Der Cooler wurde zuerst nur laut, dann war das Geräusch zu Lärm geworden. Ein Austauschdes des Coolers, nach 7 Jahren Lebensdauer war notwendig.
Minha Solução
Die Anleitung von iFixit machte die Arbeit sehr leicht. Nach einer knappen Stunde war alles erledigt und funktionierte. Nur die Tastatur wollte nicht meh . . .
Mostrar mais
