MacBook Air (Original) Fan and Heat Sink
  • MacBook Air (Original) Fan and Heat Sink
US$ 39,99
US$ 39,99
Detalhes do produto
Descrição
Descrição
An aging fan may become noisy and inefficient or simply fail and stop spinning, leaving your model A1237 MacBook Air to overheat and eventually damaging your processors. Replace a defective fan and heat sink to fix overheating problems or to keep your laptop running quietly.
O módulo contém
O módulo contém
  • Fan
  • Attached Heat Sink
Compatibilidade
Compatibilidade
  • 1.6 or 1.8 GHz Original MacBook Airs
Especificações
Especificações
Part #:
922-8316
Vídeo da instalação
Compatibilidade
MacBook Air Models A1237 and A1304
EMC 2142 1.6 GHz (Original)
EMC 2142 1.8 GHz (Original)
Histórias de Reparos
Avatar do usuário
Meu Problema
The fan was making a whistle noise... and the CPU was too hot for MBA to work normally.
Minha Solução
Changed the fan. Cleaned the inside of the laptop from dust…
Meu Conselho
Clean the inside at least twice a year…
Avatar do usuário
Meu Problema
Existing fan was loud
Minha Solução
The repair went according to instructions. I like how all the different screws are identified. Made it really easy for reinstallation.
Meu Conselho
Ifixit shows instructions on how to remove the fan from the heatsink but does not offer the option of buy the fan only. I had to buy the heatsink . . .
Avatar do usuário
Meu Problema
The machine began to run a little hot with excessive fan activity. Eventually no fan, just a faint clicking sound and rising temperatures, which I diagnosed from various blogs as fan failure.
I hadn't checked the heatsink vs processor temperatures so couldn't confirm the state of the heat sink / . . .
Avatar do usuário
Meu Problema
So, my original MacBook Air's fan started making a *horrible* very, un-Apple-like screeching sound. I added some lubrication and that helped a little, but in the end it appeared the fan unit itself had just worn out after working at thousands of RPMs for many hours thru the years.
Minha Solução
The repair took abo . . .
Mostrar mais
