MacBook Air 13" (Mid 2011) Trackpad
  • MacBook Air 13" (Mid 2011) Trackpad / With Bracket
  • MacBook Air 13" (Mid 2011) Trackpad / Without Bracket
US$ 89,99
US$ 89,99
Detalhes do produto
Descrição
Descrição
Replace a damaged trackpad and restore the touch sensitivity of your MacBook Air 13" (Mid 2011).
A worn out trackpad may have cosmetic scratches or a cracked surface causing it to malfunction. In addition, an aging trackpad may become unresponsive making your laptop difficult to control.
Compatibilidade
Compatibilidade
  • MacBook Air 13" A1369 Mid 2011
Especificações
Especificações
Part #:
922-9962
Compatibilidade
MacBook Air 13" Mid 2011
A1369 (EMC 2469) 1.7 GHz
A1369 (EMC 2469) 1.8 GHz
Histórias de Reparos
Avatar do usuário
Meu Problema
The trackpad was randomly clicking when moving the mouse. I replaced the trackpad which solved the problem.
Minha Solução
Opening the mac was not too difficult. However, unplugging the connector was tricky.
Meu Conselho
Avatar do usuário
Meu Problema
Trackpad stopped clicking got spongy when pushing down unlike before. Started to get stuck when dragging things.
Minha Solução
Man, those are some tiny screws, glad I don't have Andre the Giant hands. Took me a few tries to get the positioning of the set screw just right but no problems, no extra parts/screws, and . . .
Avatar do usuário
Meu Problema
My trackpad started randomly clicking, selecting everything, moving things around... very bad for a developer!
Minha Solução
It was a cinch. 20 minutes tops.
Meu Conselho
Spend a little time with that last adjustment screw before putting everything back together so you don't have to open it all again.
Avatar do usuário
Meu Problema
Common problem with this generation of Macs: the trackad sometimes "clicks by itself"
Minha Solução
The repair was super-simple but the excellent guide was still nice to have for safety.
Meu Conselho
By using the guides anyone can repair almost anything! However, you should read all text carefully!
Avatar do usuário
Meu Problema
Basically the trackpad that I had was registering click events when I wasn't clicking (yes, I had, and always have had, tap to click disabled). So as you can imagine, trying to open new tabs? #nope, trying to move a window? #hahanope
Minha Solução
Check out the writeup on my blog!!
http://andrew.sc/
Meu Conselho
PLEASE PLEAS . . .
Mostrar mais
