Conserte seus objetos
Direito de executar reparos
Loja
MacBook Air 13" (Late 2010) I/O Board
  • MacBook Air 13" (Late 2010) I/O Board
  • 360°
360
US$ 99,99
US$ 99,99
Detalhes do produto
Descrição
Descrição
Replace a damaged or corroded I/O board for your Late 2010 MacBook Air 13" and fix problems with charging, audio, and data connections.
  • Includes the MagSafe power, USB, and audio ports.
Compatibilidade
Compatibilidade
  • MacBook Air 13" A1369 Late 2010
Especificações
Especificações
Part #:
661-5792, 820-2861
Vídeo da instalação
Compatibilidade
MacBook Air 13" Late 2010
A1369 (EMC 2392) 1.86 GHz
A1369 (EMC 2392) 2.13 GHz
Histórias de Reparos
Avatar do usuário
Meu Problema
My Air had a dead battery and problems with the I/O unit. After five years I thought I should buy another one. A shame, because the Mac worked perfectly.
Minha Solução
The new battery and I/O unit arrived in only three days from USA to Spain, and I followed the instructions to repair. No problems. The Mac lives ag . . .
Avatar do usuário
Meu Problema
My I/O board sustained water damage while living in humid environments for the past 4 years, and it had signs of corrosion. The most annoying problem was the intermittent charging. The battery was not in the worst shape (~1200 charge cycles), but since I was opening up the case, I decided to replace . . .
Avatar do usuário
Meu Problema
Brought my Macbook Air late 2010 to Apple to fix the IO board because it would not charge any more and I could see that the contacts were very worn. Apple wanted to charge me $700 and demanded that I change the logic board too, because they said it looked as if is might have water damage. But I kn . . .
Avatar do usuário
Meu Problema
A faulty power supply damaged the power in my MacBook air. The MBA was no longer charging with any power supply! A bit of online searching revealed that the MBA has a separate IO sub board, and there was a chance that it was broken and not the whole motherboard.
I used the last of the batt . . .
Mostrar mais
