Meu Problema
My trackpad was cracked and couldn't click
Minha Solução
It went well.
Meu Conselho
I suggest using a desk lamp, bright flashlight, or any bright light. I also recommend using a small magnifying glass.
Este produto não está disponível no seu país.
Código do item: IF108-054-3
US$ 109,99
Em promoção
Peças usadas do estoque A estão em excelente estado
Peças de estoque B possuem leves marcas de uso
Peças de estoque C possuem marcas profundas de uso, mas ainda funcionam plenamente
US$ 109,99
Em promoção
Fora de estoque
Não temos tanto estoque assim disponível
Detalhes do produto
Descrição
Descrição
Replace a damaged trackpad and restore the touch sensitivity of your Mid 2013 to Early 2015 model 11" MacBook Air laptop.
A worn out trackpad may have cosmetic scratches or a cracked surface causing it to malfunction. In addition, an aging trackpad may become unresponsive making your laptop difficult to control. Fix these issues with this replacement part.
Compatibilidade
Compatibilidade
Especificações
Especificações
Compatibilidade
Histórias de Reparos
It went well.
When attempting to clean and adjustment the trackpad I ended up breaking the keyboard ribbon cable zif connector - So I ended up having to purchase a new trackpad.
The new trackpad was replaced with out any issues. The zif connector is a bit finicky for attaching both the trackpad ribbon and the keyboard ribbon. My laptop now works great - so I'm happy.
Be really careful when lifting the zif connectors to remove and insert the ribbons. It's very thin plastic and if it breaks you have to replace the entire trackpad. I used the All-new Pro Tech Toolkit, which is awesome. Great tools, great case. Highly recommend this kit - I
The new trackpad was replaced with out any issues. The zif connector is a bit finicky for attaching both the trackpad ribbon and the keyb . . .
Clientes também compraram
Produtos destacados
