Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
MacBook Air 11" (Late 2010) Trackpad
  • MacBook Air 11" (Late 2010) Trackpad
  • 360°
360
US$ 49,99
US$ 49,99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Kit de pontas universal para chave
112 bits for every fix.
Upgrade Your Toolbox
Detalhes do produto
Descrição
Descrição
Replace a damaged trackpad and restore the touch sensitivity of your MacBook Air 11" (Late 2010).
A worn out trackpad may have cosmetic scratches or a cracked surface causing it to malfunction. In addition, an aging trackpad may become unresponsive making your laptop difficult to control.
Compatibilidade
Compatibilidade
  • MacBook Air 11" A1370 Late 2010 1.4 GHz or 1.6 GHz
Especificações
Especificações
Part #:
922-9670
Compatibilidade
MacBook Air 11" Late 2010
A1370 (EMC 2393) 1.4 GHz
A1370 (EMC 2393) 1.6 GHz
Histórias de Reparos
Avatar do usuário
Meu Problema
Skippy trackpad, basically unusable. Also would detected phantom inputs which would trigger the contextual menu unexpectedly
Minha Solução
Without a hitch - great walk through
Meu Conselho
Everything one should know is in the walk through - take heed to the "be gentle on the hinges" advice
Avatar do usuário
Meu Problema
No possible click on at the left side of the trackpad.
Minha Solução
With the exact repair procedure with photos from Ifixt, the replacement of trackpad was possible without any problems.
Meu Conselho
I bought a PRO TECH TOOLKIT, unfortunately the Pentalobe screwdriver used for the repair of the Macbook Air aren't Pro. The fi . . .
