MacBook 13.3" LCD Panel
  • MacBook 13.3" LCD Panel
Glossy finish screen. LCD is new and in excellent condition.
The part you receive may or may not have the screw holes on top of the LCD. You can still use the part even though you do not use those screws.
$49.99
$49.99
Enviaremos uma mensagem quando o produto estiver disponível em estoque.
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
Detalhes do produto
Descrição
Descrição
Replace your cracked or damaged MacBook LCD with this part. This part is compatible with all 13.3" (1280x800) MacBooks (excluding MacBook Unibody and MacBook Air).
Nota
This part does not include the backlight inverter and is not compatible with any MacBook Unibody, Pro, or Air models.
Compatibilidade
MacBook Core 2 Duo
1.83 GHz
2 GHz (Early 2009)
2 GHz (Late 2006)
2 GHz (Mid 2007)
2 GHz (Santa Rosa)
2.1 GHz (Penryn)
2.13 GHz (Mid 2009)
2.16 GHz
2.2 GHz (Santa Rosa)
2.4 GHz (Penryn)
MacBook Core Duo
1.83 GHz
2 GHz
Histórias de Reparos
Adam Cox's Story Photo #318482
Adam Cox's Story Photo #318483
Meu Problema
I was asked to fix a backlight issue on a 2008 13" black MacBook Penryn by a client. The screen was showing, but the backlight wouldn't turn on and would only flicker when you played with the F1 & F2 keys.
Minha Solução
I tried replacing the display inverter first, but that only worked for about an hour. That's wh . . .
public1's Story Photo #344437
public1's Story Photo #344439
Meu Problema
We gave my old MacBook to my father-in-law's caregiver so she could work on some language courses and connect to some safety monitors. But it turned out that my optical drive had gotten flaky since I'd last used it and I already knew that the screen had a vertical bar with a different intensity, pr . . .
Meu Problema
Because I could not see half of my screen.
Minha Solução
It Was painless with the ifix.com it guide.
Meu Conselho
Take your time and be careful with the housing for the keyboard connector super easy to damage!!
Meu Problema
Minha Solução
Meu Conselho
Meu Problema
I had my wife's Macbook with us on vacation. We travelled in a van through Australia. One time I accidentally stepped on the Macbook which was underneath a pile of clothes. The only thing that was broken was the LCD screen. A serious area contained dead black pixels.
I ordered recently a new . . .
Meu Problema
The screen in the MacBook (Early 2009) had no light. First I changed the inverter and inverter cable but still no light. So I decided to change the LCD panel as well and this did the trick.
Minha Solução
I followed the guide to change the LCD panel and had no big problems.
Meu Conselho
Invest in proper tools! Screwdrivers and . . .
Meu Problema
My dear lappy's screen has been broken for three years. I've had a PC monitor hooked to it, effectively making it the world's only desk-bound laptop. Frankintosh still ran well, though. I had to do something.
Minha Solução
"Oh, this is pretty easy, doot doot doo. I mean, if I can do this without--what the !&&* is . . .
Meu Problema
Older macbook, but still a nice computer. After being dropped there were several cracks obscuring the display.
Minha Solução
I used the "long" technique completely removing the display from the laptop. It took me 2 hours to complete the disassembly and 90 minutes to put it back together again. The instructions wer . . .
Meu Problema
Cracked screen
Minha Solução
Done. Easy!
Meu Conselho
Patience.
Meu Problema
My 4 year old son decided to be rough with the MacBook closing the lid one night.
Minha Solução
One order from you and 2.5 hours later the screen was replaced. Your guides rock.
Meu Conselho
Set aside 2.5 to 3 hours to do this job completely.
Mostrar mais
