MacBook 13" Unibody (Model A1278) Logic Boards
Grab a toolkit for your MacBook 13" Unibody (Model A1278) model and fix your broken laptop!
iFixit has you covered with parts, tools, and free repair guides. Repair with confidence! All of our replacement parts are tested to rigorous standards and backed by our industry-leading warranty.
Escolha seu modelo de MacBook 13" Unibody (Model A1278):
Peças compatíveis com MacBook 13" Unibody (Model A1278):
MacBook Unibody (A1278) 2 GHz Logic Board
Replace a 2 GHz logic board (motherboard) compatible with the MacBook Unibody (A1278) laptop. Fix processing issues like unexpected shutdowns, reboots, or water damage. I...
MacBook Unibody (A1278) 2.4 GHz Logic Board
Replace a 2.4 GHz logic board (motherboard) compatible with the Model A1278 MacBook Unibody laptop. Fix processing issues like unexpected shutdowns, reboots, or water da...
Informações do dispositivo
Apple's introduction of the MacBook Unibody 13" introduced a new case milled from a single brick of aluminum. Also new to this version is a switch to SATA optical drives and the controversial loss of a Firewire port.
The MacBook Unibody 13" can be upgraded to 8GB of RAM using two PC3-8500 4 GB RAM chips. The hard drive can also be upgraded to a hefty, yet agile 500 GB 7200 RPM SATA hard drive.
Not sure what's wrong with your laptop? Check out our Troubleshooting Guide!
Select your machine above or browse all compatible parts to find what you need to fix your laptop!
