Peças Mac MacBook 13" Penryn Headphone Jacks
Loja
Não sabe qual é o seu modelo? Identifique seu Mac
Arctic Silver Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating. 3.5 grams
US$8,99
MacBook and MacBook Pro (Non-Retina) SSD Upgrade Bundle
Upgrade the storage and improve boot time and read/write speed in your MacBook and MacBook Pro (Non-Retina) with this SSD upgrade bundle.
De US$89,99
Arctic Silver ArctiClean
Two part cleaner dissolves old thermal paste on heat sinks and processors. One 30 ml bottle of thermal material remover and one 30 ml bottle of thermal surface purifier.
US$7,99
Silicone 2.5" Hard Drive Enclosure with USB 2.0 Cable
Turn any SATA 2.5" laptop hard drive into an external storage drive with this part.
US$9,99
500 GB 5400 RPM 2.5" Hard Drive / Toshiba
Replacement or upgrade hard drive compatible with all MacBooks, MacBook Pros, Intel Mac minis, and Sony PS3 and PS3 Slim game consoles. SATA interface for Intel Macs / 2....
US$54,99
Universal Drive Adapter
Turn your current hard drive into an external drive with this part.
US$24,99
MacBook Replacement Battery / White / New
Replace your dying or broken battery with this replacement. Compatible with all 13.3" MacBooks (excluding MacBook Unibody and MacBook Air). 4900-5200 mAh, 55 Watt Hours (...
US$79,99
MacBook Display Inverter
Replace a broken or damaged display inverter for your MacBook with this part and fix backlight issues. This part is compatible with all 13.3" MacBooks (excluding MacBook ...
US$14,99
G4/MagSafe AC Adapter End
Replace a broken or damaged two-pronged tip of your square G4 or MagSafe adapter with this part.
US$7,99
PC2-5300 1 GB RAM Chip
RAM Upgrade / 1 GB / PC2-5300 / Low Profile / 200 pin, 667 MHz
US$8,99
Mostrando produtos 1 - 10 de 60
Informações do dispositivo
Apple introduced a small speed bump with the Penryn version of MacBook.
The MacBook 13" Penryn laptop can be upgraded to a total of 6 GB of memory using a 4 GB RAM chip and a 2 GB RAM chip. Don't let all that RAM be wasted with a slow hard drive. The 500 GB 7200 RPM SATA hard drive will give you plenty of storage. The fastest optical drive for this model is the 8x SuperDrive and it will make burning CDs a breeze.
Check out our MacBook troubleshooting page for help in diagnosing your machine!
Select your category below or browse all compatible parts to find what you need to fix your laptop!
