Intel Mac mini (Model A1176) Fan
  • Intel Mac mini (Model A1176) Fan
US$ 54,99
US$ 54,99
Detalhes do produto
Descrição
Descrição
Replace a malfunctioning fan to fix overheating problems and keep your Intel Mac mini (Model A1176) running quietly.
  • This part includes the fan and its surrounding plastic bracket.
An aging fan may become noisy and inefficient or simply fail and stop spinning, leaving your fan to overheat and eventually damage your processors.
Compatibilidade
Compatibilidade
  • Mac mini A1176 Early 2006 to Mid 2007
Especificações
Especificações
Part #:
922-7317, 720-0639
Compatibilidade
Mac mini Model A1176
1.5 GHz (Core Solo)
1.66 GHz (Core Duo, Early 2006)
1.66 GHz (Core Duo, Late 2006)
1.83 GHz (Core 2 Duo, Mid 2007)
1.83 GHz (Core Duo, Late 2006)
2 GHz (Core 2 Duo)
Histórias de Reparos
Avatar do usuário
Meu Problema
I think the bearinga in the fan wore out and it was getting pretty noisy. I could have lived with that, bit the computer was overheating and shutting down in the summer.
Minha Solução
It was pretty obvious, it is frightening to open the housing first. Patience is key, there are small wires which I guess are really . . .
Avatar do usuário
Meu Problema
i've been running a rig with 2 Mac Mini's. i need one to run Windows on for my work platform, and another one because i hate Windows for my personal computing. the older one i use for Windows was running hot. it needed a new fan. it can't die. i must work!! with this fix in place, it keeps on trucki . . .
Avatar do usuário
Meu Problema
It has been running for 4 years and sounded like it was on its way to die.
Minha Solução
Excellent - really not a big deal using the guide from iFixit
Meu Conselho
My MacMini had another number (A1174 I believe) but it was the same fan anyway.
Avatar do usuário
Meu Problema
Using an old mac mini as a lossless music server, the noisy fan in my mac mini spoilt my listening. A replacement fan from ifixit was ordered and promptly delivered.
Minha Solução
Installation not the easiest job; step by step ifixit guide was easy to follow, informative and very comprehensive. Complete success a . . .
Avatar do usuário
Meu Problema
The fan was failing... so I needed to change it!
Minha Solução
Pretty fast! no problem
Meu Conselho
Don't worry, just chek out your order, an faster than you think twice, you'll have it to change it!
Avatar do usuário
Meu Problema
A couple of weeks ago we had had a power spike in the night. End result, our 5 year old Mac Mini that still does sterling service as a media centre (thanks Plex!), burnt out its fan and overheated to the point of powering off the next time we used it.
Minha Solução
Opening this generation of Mac Mini feels intimid . . .
Avatar do usuário
Meu Problema
My Mac Mini (2007) had become very loud. You could hear the whine from the fan whenever it was running bigger jobs.
I also had tried to upgrade to OSX Lion. When I tried to it said I needed more than the 1GB I had in the the machine. I had some ram handy so I wanted to upgrade from 1GB to 4GB.
Minha Solução
Th . . .
Mostrar mais
