2 TB SSD Hybrid 3.5" Hard Drive
  • 2 TB SSD Hybrid 3.5" Hard Drive / Part Only
US$ 144,99
US$ 144,99
Detalhes do produto
Descrição
Descrição
Replace or upgrade the hard drive in your compatible iMac with this part.
Compatibilidade
Compatibilidade
  • iMac G5 17" EMC 2055
  • iMac G5 20"
  • All 21.5" and 27" pre 2011 Intel iMacs
  • All G5 Power Macs
Especificações
Especificações
Model #:
ST2000DX002
Cache:
64 MB
Drive Capacity:
2 TB Unformatted
Speed:
Hybrid, 5400 RPM
Interface:
SATA 6.0 Gb/s
Dimensions:
3.5" wide x 1" tall / 89 x 25mm
Compatibilidade
iMac G5 17" Model A1058
1.8 GHz (EMC No. 2055)
2 GHz
iMac G5 17" Model A1144
1.9 GHz
iMac G5 20" Model A1076
1.8 GHz
2 GHz
iMac G5 20" Model A1145
2.1 GHz
iMac Intel 17"
1.83 GHz (EMC No. 2104)
1.83 GHz (EMC No. 2110)
1.83 GHz (EMC No. 2124)
2 GHz
2.16 GHz
iMac Intel 20" EMC 2105 and 2118
2 GHz
2.16 GHz
2.33 GHz
iMac Intel 20" EMC 2133 and 2210
2 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2133)
2.4 GHz (EMC No. 2210)
2.66 GHz (EMC No. 2210)
iMac Intel 20" EMC 2266
2.66 GHz
iMac Intel 21.5" EMC 2308
A1311 Late 2009 iMac10,1 3.06 GHz
A1311 Late 2009 iMac10,1 3.33 GHz
iMac Intel 21.5" EMC 2389
A1311 Mid 2010 iMac11,2 3.06 GHz
A1311 Mid 2010 iMac11,2 3.2 GHz
A1311 Mid 2010 iMac11,2 3.6 GHz
iMac Intel 24" EMC 2111
2.16 GHz
2.33 GHz
iMac Intel 24" EMC 2134 and 2211
2.4 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2134)
2.8 GHz (EMC No. 2211)
3.06 GHz (EMC No. 2211)
iMac Intel 24" EMC 2267
2.66 GHz
2.93 GHz
3.06 GHz
iMac Intel 27" EMC 2309 & 2374
EMC 2309 Late 2009 iMac10,1 3.06 GHz
EMC 2309 Late 2009 iMac10,1 3.33 GHz
EMC 2374 Late 2009 iMac11,1 2.66 GHz
EMC 2374 Late 2009 iMac11,1 2.8 GHz
iMac Intel 27" EMC 2390
A1312 Mid 2010 iMac11,3 2.8 GHz
A1312 Mid 2010 iMac11,3 2.93 GHz
A1312 Mid 2010 iMac11,3 3.2 GHz
A1312 Mid 2010 iMac11,3 3.6 GHz
Power Mac G5
1.6 GHz
1.8 GHz (EMC No. 1969)
1.8 GHz (Late 2004)
1.8 GHz Dual (EMC No. 1969)
1.8 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 1969)
2.0 GHz Dual (EMC No. 1969C)
2.0 GHz Dual (EMC No. 2023)
2.0 GHz Dual (EMC No. 2061)
2.3 GHz Dual (EMC No. 2023)
2.3 GHz Dual (EMC No. 2061)
2.5 GHz Dual (EMC No. 1969C)
2.5 GHz Quad
2.7 GHz Dual
Mostrar mais 13 dispositivos
Histórias de Reparos
Avatar do usuário
Meu Problema
I had a 1TB Seagate drive that was getting increasingly slower and was making an intermittent grinding noise while my Mac was asleep.
Minha Solução
The repair guide was spot on!!! Be sure to read all of the comments with the associated steps, as they can be very insightful! From start to finish the repair took les . . .
Avatar do usuário
Meu Problema
2008 iMac was getting increasingly slow. No problems diagnosed—it was just getting old, taking ages to open applications—and driving me nuts. I was nervous about putting an SSD into my iMac—having to remove the screen, etc.—seemed a bit daunting.
Minha Solução
Had the whole job done within an hour. So much . . .
Avatar do usuário
Meu Problema
After loading Yosemite and more and more documents and programs the imac mid 2010 worked in some parts to slow and with irregularities. So in a first step I doubled the RAM from 4 to 8 GB. The actual next step was to increase the storage capacity from a 0.5 HD to a 2 TB SSD Hybrid 3.5".
Minha Solução
I worked me t . . .
Avatar do usuário
Meu Problema
S.MA.R.T read error would not let me upgrade to OS X Yosemite.
Minha Solução
Repair was straight forward. I nearly ruined the Monitor Connection when I first removed the monitor to check the HDD, The instructions given on the guide are clear, I just misread them. Second time around I didn't remove the monitor.
Meu Conselho
If y . . .
Avatar do usuário
Meu Problema
The problem was I listened to my computer experts in the repair business. Approximately 3 months after my warranty on IMAX ran out my computer completely shut down. Being most computer illiterate and needing it for my business I immediately took my IMAX into the computer experts, a high profile comp . . .
Avatar do usuário
patrickhonings's Story Photo #482516
patrickhonings's Story Photo #482515
Meu Problema
HDD-failure
Minha Solução
Slow tempo about an hour. No problems and no mistakes, thanks to the guide of Brittany McCrigler: iMac Intel 24" EMC 2134 and 2211 Hard Drive Replacement
Meu Conselho
The only thing that I didn't follow, was step 11 "disconnect the LCD cable by pulling down". I disconnected it from the lcd-screen itsel . . .
Mostrar mais
