Conserte seus objetos
Direito de executar reparos
Loja
12.7 mm SATA 8x SuperDrive
  • 12.7 mm SATA 8x SuperDrive
US$ 49,99
US$ 49,99
Detalhes do produto
Descrição
Descrição
This dual-layer SATA drive does not include the metal mounting bracket and the orange ribbon cable.
Compatibilidade
Compatibilidade
  • All Model A1283 Mac minis
  • Mid 2010 Model A1347 Mac minis
  • iMac Intel 20" EMC 2266
  • iMac Intel 24" EMC 2267
  • iMac Intel 21.5" EMC 2308 and 2389
  • iMac Intel 27" EMC 2309 and 2374
Especificações
Especificações
Speed:
5x DVD-RAM write
8x DVD+R write (SL)
8x DVD-R write (SL)
6x DVD-R write (DL)
6x DVD+R write (DL)
6x DVD-RW write
8x DVD+RW write
24x CD-R write
24x CD-RW write
8x DVD read
24x CD read
Compatibilidade
2.66 GHz
A1311 Late 2009 iMac10,1 3.06 GHz
A1311 Late 2009 iMac10,1 3.33 GHz
iMac Intel 21.5" EMC 2389
A1311 Mid 2010 iMac11,2 3.06 GHz
A1311 Mid 2010 iMac11,2 3.2 GHz
A1311 Mid 2010 iMac11,2 3.6 GHz
2.66 GHz
2.93 GHz
3.06 GHz
iMac Intel 27" EMC 2309 & 2374
EMC 2309 Late 2009 iMac10,1 3.06 GHz
EMC 2309 Late 2009 iMac10,1 3.33 GHz
EMC 2374 Late 2009 iMac11,1 2.66 GHz
EMC 2374 Late 2009 iMac11,1 2.8 GHz
Mac mini Mid 2010
A1347 (EMC 2364) 2.4 GHz (Core 2 Duo, Mid 2010)
A1347 (EMC 2364) 2.66 GHz (Core 2 Duo, Mid 2010)
Mac mini Model A1283
2 GHz (Core 2 Duo)
2.26 GHz
2.53 GHz
2.66 GHz
Mostrar mais 4 dispositivos
Histórias de Reparos
Avatar do usuário
paulchernoff's Story Photo #177310
Meu Problema
The optical drive needed replacing. As long as I had the Mac mini opened I decided to also upgrade the hard disk.
Minha Solução
To my shock everything worked once I was done and there weren't any screws left over. It was nerve wracking, the Mac mini isn't designed for home repairs. If I knew beforehand how difficu . . .
Avatar do usuário
Meu Problema
Optical drive was going out, only reading discs half the time.
Minha Solução
Very smoothly, much easier than I had anticipated.
Meu Conselho
Everything is pretty straightforward once you get the outer case off and start digging around inside. Just make sure you keep track of all the parts and be very careful when removing the . . .
Avatar do usuário
Meu Problema
My Optical drive would not read a CD and it made a horrible noise. I used the guide and opened the case to find a few of the tiny gears from the original drive had fallen out. It was obvious that one of my children had tried to insert more than one CD in the drive.
Minha Solução
I ordered a used drive, used the gu . . .
