Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2375 Perguntas Visualizar todos
Pergunta encerrada
How to put back on front camera retainer?
Does anyone have any advice on how best to put back on the front camera retainer in an iPhone 4 & 4S? It is quite hard to get all 3 clips engaged. I usually settle for only 2 when putting this piece back, but it makes the front camera not centered.
Thanks!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
I normally use a pair of tweezers. Start with the right side first, then the bottom and then the top. You have to make sure the retainer clips go on the outside of the points where they attach. But you are right, this is a very difficult thing to get back in to place. Good luck!
Esta resposta foi útil?
Pontuação 6
I fought with this for a long time and thought I had ruined the clip. Then I stumbled upon your great description and realized I had been trying to get the clips to fit on the inside of the brackets instead of the outside! I though I had ruined the clips legs until I read your post. Thank you.
Pontuação 1
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,099
