Huawei released the Pura 70 line of smartphones in April 2024 and it’s already made a bit of a stir. Last year, another Huawei smartphone, the Mate 60, surprised the world with an advanced 7nm-process System on Chip—despite US sanctions that limited Chinese access to the latest lithography machines. Sure, it was still years behind other semiconductor manufacturers, which had moved on to 3nm-process chips. But they caught up faster than most expected.
As the tech world anticipated this new smartphone, everyone wanted to know: Has China continued to advance its semiconductor manufacturing processes, in defiance of sanctions? Is the chip in the Pura 70 new? Better? Where is it made, and on what equipment?
To get some answers, we tore down the Pura 70 Pro in collaboration with our partners at TechSearch International.
A Closer Look at the Kirin 9010
Thanks to those same sanctions, we couldn’t get a Pura 70 in our US office. But we got some help from Reuters, who worked with our team in Shenzhen to do a midnight teardown and get a closer look at the phone’s new silicon—which is, we discovered, the new Kirin 9010 System on Chip.
![](https://valkyrie.cdn.ifixit.com/media/2024/05/07182638/daniel-chip.jpg)
Like many modern SoC packages, the Kirin 9010 processor sits underneath the DRAM module, the 12GB SK Hynix chip in this instance. Removing the chip reveals the processor.
![](https://valkyrie.cdn.ifixit.com/media/2024/05/07182711/Shenzhen-decap.jpg)
From this image, one detail stood out. The external markings seemed to match the older Kirin 9000S which was produced on SMIC’s 7nm node, commonly referred to as N+2. We ran this by one of our industry experts, and they noted that the chip identifiers in particular were unusual in that a new chip usually has its own model number. Not in this case: the 9000S (model HI36A0 revision GFCV120) and the 9010 (model HI36A0 revision GFCV121) share the same model number.
![](https://valkyrie.cdn.ifixit.com/media/2024/05/07183416/9000S-v-9010.jpg)
In the days that followed, we saw similar sentiments appear online. TechInsights suggested that the Kirin 9010 appeared to be on the same N+2 process node. The prevailing theory is that the Kirin 9010 is, at its heart, a 9000S with a revised design aimed at improving production yields. The improvements may not be limited to production though—early benchmarks suggest that the 9010 also performs a little better than the 9000S.
This is significant because news of the 9000S on a 7nm node caused a bit of a panic last year when US lawmakers were confronted with the possibility that the sanctions imposed on Chinese chip makers might not slow their technological progress after all. The fact that the 9010 is still a 7nm process chip, and that it’s so close to the 9000S, might seem to suggest that Chinese chip manufacturing has indeed been slowed. But don’t underestimate Huawei. SMIC (Semiconductor Manufacturing International Corporation) is still expected to make the leap to an N5 equivalent node before the end of the year, if not shortly thereafter. They already possess the technology and know-how; it’s simply a matter of achieving commercially viable yields.
![](https://valkyrie.cdn.ifixit.com/media/2024/05/07183532/chip-ID.jpg)
Still, there’s no question that the Chinese semiconductor industry is trailing several years behind TSMC, Global Foundries, Samsung, and other Western-aligned fabs with access to ASML’s EUV (Extreme Ultraviolet) photolithography machines. SMIC was unable to progress to the 5nm node process since the release of the 9000S while TSMC has an N2 node in its sights—a generational difference of 3 nodes representing six years of process refinement. That should put the technical challenges facing China’s semiconductor industry into perspective.
Looking at the benchmarks between the 9000S, 9010, and 2023’s Qualcomm Snapdragon 8 Gen 3 produced by TSMC shows how far Chinese semiconductor manufacturing has come, but also how far they have to go. The Kirin 9010 performs staggeringly worse than TSMC’s N4P derived Snapdragon 8 Gen3. N4P is a node process derived from the N5 node and announced by TSMC back in 2021 and its N5 parent node is only a single generation apart from the N7 node of the Kirin 9000S and 9010. Meanwhile, the performance increase between the 9000S and 9010 remains in single digits. This new SoC is marginally better but not the huge leap that was expected.
![](https://valkyrie.cdn.ifixit.com/media/2024/05/07183615/Benchmarks.jpg)
To achieve those single-digit performance increases, the Kirin 9010’s 12-core SoC uses six ARM Cortex A510 efficiency cores running at 1550 MHz paired with four Taishan v121 cores running at 2180 MHz and two Taishan v121 cores running at 2300 MHz.
By comparison, the 9000S is reported to have an 8-core SoC (confusingly there are lots of benchmarks that report 12 cores ever since a recent HarmonyOS update but this is unlikely) containing four ARM Cortex A510’s running at 1530 MHz paired with three Taishan cores running at 2150 MHz and one Taishan v120 core running at 2620 MHz.
The Taishan cores are custom ARM Cortex processors and the version numbers provide some insight into the revision number printed on the chip. The A510 itself is an ARM Cortex processor from 2020, since superseded by the A520.
![](https://valkyrie.cdn.ifixit.com/media/2024/05/07183753/Snapdragon-8-Gen-3-Benchmarks.jpg)
Made in China…Mostly
It’s notable to see that the Huawei Pura 70 is close to becoming China’s poster child for self sufficiency. The majority of the chips we found are designed and manufactured in China with a couple of notable exceptions.
SK Hynix was notably present, despite claiming that they had not sold anything to Huawei since sanctions kicked in back in 2020. It’s very possible that these chips are the last of a dwindling stock of SK Hynix IC’s.
The other big name presence on the PCB was Bosch, with their 6-axis gyroscope and accelerometer MEMS sensor. As a global leader in the supply and design of MEMS sensors, Bosch’s presence would not raise any eyebrows were it not for the fact that Chinese manufacturers probably have the ability to produce these sensors locally.
You can find our full chip ID on our website.
NAND Flash Memory
But perhaps the most interesting IC inside the Pura 70 Pro is HiSilicon’s 1TB NAND flash memory. It’s worth noting that the European markets can only get the 256GB and 512GB NAND modules.
![](https://valkyrie.cdn.ifixit.com/media/2024/05/07194453/NAND-package-top-1.jpg)
What’s so interesting about this package? Our friends at Creative Electron provided us with an X-ray while TechSearch provided analysis to help unpack this little beauty.
![](https://valkyrie.cdn.ifixit.com/media/2024/05/07184333/NAND-xray-side.jpg)
From the analysis provided, we think it’s possible that HiSilicon may have produced the memory controller and performed the testing and packaging of the NAND chip but a lack of markings on the memory controller itself means we can’t be sure.
![](https://valkyrie.cdn.ifixit.com/media/2024/05/07185947/NAND-controller.jpg)
It’s very unlikely that HiSilicon would be able to produce the NAND dies themselves. Again, we’ve been unable to locate any markings on the dies to positively identify the manufacturer but it’s highly likely that they were designed and made locally by another Chinese manufacturer.
![](https://valkyrie.cdn.ifixit.com/media/2024/05/07190231/NAND-IC-die.jpg)
It’s All About Yield
There’s no question that China has the expertise to become a self-sufficient semiconductor powerhouse. At least in theory. The immediate bottleneck to advancement is their lack of access to advanced photolithography systems.
It’s fully expected that China will be able to use multi-patterning techniques with their existing DUV (Deep Ultraviolet) photolithography machines to reach an N5 equivalent node. This will happen and there will likely be a wave of alarmism that will follow. However, the shortages and backlogs on orders for Huawei’s Pura 70 and even the months-old Mate 60 imply that, as analysts had predicted, the N+2 process does not produce sufficient yields to meet demand. This restricts SMIC’s ability to produce the 7nm Kirin 9000S and 9010 SoC’s in large enough quantities to meet demand.
Adding to this bottleneck is Huawei’s inability to source LPDDR5 chips from their usual suppliers in the international market due to US sanctions. It seems that so far the Chinese smartphone manufacturer has been able to get around this by relying on a stockpile of chips purchased prior to the 2020 sanctions going into effect. However, those stocks must be dwindling at a rapid rate.
This is where CXMT comes in. As China’s premiere DRAM fab, they’ve recently produced the first fully Chinese-manufactured LPDDR5 module which we expect to start seeing in the wild soon. However, DRAM also relies heavily on the latest node processes for performance and power efficiency. Again, as CXMT attempts to produce on 7nm and 5nm nodes, they will have to grapple with the problem of production yields dropping significantly.
Looking Past 5nm
For now, the US has successfully restrained China’s ability to mass produce on the 7nm node at high yields. By extension, it has also prevented China from mass producing on an N5 equivalent node at high yields. And yet this has not prevented China from progressing in other areas, notably as a market leader and innovator in 3D NAND technology.
The biggest challenge currently facing the Chinese semiconductor sector is their inability to access the latest node processes. The EUV photolithography machines that enable economical and scalable production of N3 nodes and beyond are exclusively manufactured and sold by a single company in the Netherlands: ASML. While US sanctions remain in effect, Chinese fabricators will be forced to deal with lower yields and higher costs for older tech while simultaneously pouring money into R&D to develop their own EUV and DUV photolithography systems.
Despite these challenges, China is expected to make the leap from a 7nm node process to 5nm imminently, though production yields are likely to remain low. Meanwhile, CXMT (ChangXin Memory Technologies) is predicted to replace SK Hynix as pre-sanctions stocks of LPDDR5 dwindle.
We expect to see a 5nm node from these fabs. The question is, where will they go from there? Rest assured, we’ll be keeping our eyes—and our screwdrivers—on Huawei.
6 comentários
Will Huawei (and largely Chinese Semiconductor industry) survive and thrive?
David Comin - Responder
There is no doubt, the only concern is the timing period to catch up the leading edge.
Wilson HU -
Why does this issue about yield on the Kirin chip keep coming up when several experts like Dan Hutcheson from TechInsights (https://www.reuters.com/technology/huawe...), Paul Triolo and TP Huang have all pointed out the yield is certainly above 50 percent? If production was constrained by limits on production of the chip they would be a corresponding drop in supply while Huawei lingers at the bottom of the smartphone market in China. Instead Huawei now has the largest market share in China’s vast smartphone market according to both Canalys and Counterpoint–having fully regained its dominance, which clearly proves that supply issues are around sustained demand for the phone not supply constraints. Additionally Huawei has eaten into significant market share at the top end of the smartphone market in China with Apple losing ground–dropping from 75% market share to 59% as Huawei gains ground on the back of the Mate 60. Xiaomi SU7 proves even China sometimes can’t keep up with demands of its people.
Beta __ - Responder
The yield is low when compared to more efficient processes. Dan says himself in your linked article that they probably “yield ok”. Not 90% as is industry standard at this node but probably higher than 50%.
Yes supply and demand is tricky to gauge but a low yield defined as anything less than the industry standard 90% certainly exacerbates the problem.
Shahram Mokhtari -
This is the link from previous comment: Huawei's new smartphone uses more China-made parts than previous models, TechInsights says - Dan Hutcheson
Beta __ - Responder
