Last month, I pulled my old K-Mix USB audio mixer out of the bottom drawer, and it was covered with dust and sticky goo. The reason? Its soft-touch coating, which lends a luxurious feel to plastic surfaces when new, had deteriorated. So, of course, I set to fixing it.
Sticking Point
Why do manufacturers use these soft coatings in the first place? One reason is that they really do feel great at first. Instead of hard, smooth, cheap-feeling plastic, you get a rubbery touch that feels pretty classy. And these coatings can also hide surface flaws from the injection-molding process. As a comparison, I have a pair of Genelec speakers in raw, unfinished aluminum, and they look great, but the aluminum surface is flawed, patchy, and shows sanding marks. It’s a look that many people dig, but that’s aluminum. Flawed plastic is less attractive.
The problem with these materials is that they break down over time, and end up either tacky and covered in dust, or actually sticky, so when you touch them they feel gross, almost like you spilled juice or honey on them. To make plastics feel soft, manufacturers use compounding additives like oils, antioxidants, and stabilizers that can come to the surface over time and create a sticky feeling. This process is called plasticizer migration. It’s a problem well-known both in car dashboards and guitar knobs.
![Sticky plastic on the bottom of the K-Mix mixer](https://valkyrie.cdn.ifixit.com/media/2024/04/05145305/kmix-5.jpeg)
The best way to avoid this is to not buy soft-coated products. You can slow down plasticizer migration by keeping your stuff cooler—it happens faster at higher temperatures. But if you’re here, reading this, it’s probably too late for that.
Also, it’s not always obvious which surfaces will break down. That’s because there’s not just one material that causes this. While soft-touch plastics are a likely candidate, other materials can get sticky too. Rubber stuff goes sticky through a process called “rubber reversion.” Turning the sticky sap of the rubber tree into car tires and game controller grips requires heating it with sulfur and other additives. This curing process, called vulcanization, makes the sap’s polymer chains join together into a strong, stretchy matrix. When those polymer crosslinks break down with time and heat, the rubber gets sticky again.
Nikon’s F100 film SLR, from 1999, has a pretty standard rubberized finish, for example, but it’s notorious for going sticky. I gave mine to my dad, and then, years later, he gave it back, and the rubber was tacky and unpleasant, and attracted dust. But I fixed it.
Smooth Operator
As long as your sticky thing has no sensitive electronics, your best bet is to start the cleaning process with warm, soapy water. In a lot of cases, soap will loosen the migrated plasticizers and restore a non-sticky finish.
If soap and water don’t do the trick, you could try baking soda: Add enough water to turn the baking soda into a slurry paste. Spread it on the sticky surface, let it sit for 15 minutes, and then wipe it away.
If it’s still sticky, you’ll need to find a solvent. Always be sure to test a small, unobtrusive area first: Depending on the plastic and plasticizers involved, a solvent could actually break down the plastic further and make it more sticky. For this reason, we recommend staying away from solvents if you’ve got a sticky car steering wheel.
The go-to solvent for cleaning up sticky plastic is isopropyl alcohol. Pure, or almost-pure, alcohol is good for electronics use because it is non-conductive. We have a full guide on isopropyl alcohol for all the details, but for cleaning purposes, here’s what you need to know.
Isopropyl alcohol dissolves oils, kills viruses and bacteria, and evaporates without leaving a trace. For cleaning sensitive electronics components, you want the pure stuff, 90% alcohol or higher. But for cleaning sticky plastics or rubber, you can get away with lower concentrations, because you don’t have to worry about anything shorting out with residue. If it does leave visible impurities from the water, you can just clean again. Take a look at the list of ingredients: Whatever you’re using should be nothing more than isopropyl alcohol and water. “Rubbing alcohol” often includes fragrances or other chemicals that might not play well with your gadgets, and they will probably also leave a smell (even though it may be a smell you like).
![Trying to scrape off the sticky plastic coating with a Jimmy](https://valkyrie.cdn.ifixit.com/media/2024/04/05145307/kmix-4.jpeg)
For the Nikon’s rubber, the fix is to gently rub it with isopropyl alcohol. Avoid drips, and go slow. It may take multiple applications to fix, but eventually, the rubber will stop feeling sticky and instead feel like, well, like grippy rubber. Pro tip: don’t use toilet paper when cleaning with alcohol, as it disintegrates immediately and just adds to the problem. I use squares ripped from old cotton t-shirts, and they work well.
For the K-Mix mixer, pictured here in all its sticky-finished shame, the situation was more dire. Even after an isopropyl rub, the coating stayed tacky. As you can see, I was able to scrape much of the coating off and then use isopropyl alcohol as a soak/scrub to finish the job.
![The underside of the K-Mix mixer, cleaned of its sticky residue](https://valkyrie.cdn.ifixit.com/media/2024/04/05145311/kmix-2.jpeg)
The best way for this particular job would be to disassemble the entire unit to remove just the case, scrape it (with a plastic scraper like a Halberd spudger or plastic card, preferably, so you don’t scratch the surface), and then soak the case to remove the remainder.
Other Solvents
![](https://valkyrie.cdn.ifixit.com/media/2024/04/04161257/light_naphtha_fire_breathing.jpg)
Sometimes, however, alcohol isn’t the answer. For example, if you remove the paper labels from some food jars, the residual glue is best removed with lighter fluid, aka light naphtha, the kind of fuel you’d drip into a Zippo lighter. But if you are using lighter fluid to clean something other than glass, you should definitely test it first, to make sure it doesn’t destroy the underlying plastic itself.
One fun fact about lighter fluid is that it is safe for cleaning vintage electric guitars with their delicate nitrocellulose lacquer finishes. But in that case, you should definitely avoid acetone, which will “melt” the finish (anecdotally, you might also avoid DEET-based insect repellents while playing outdoor gigs, for the same reason).
Acetone, best known as nail polish remover, has its uses. We use it in our adhesive remover, for example. But it can damage ABS plastics, which is a shame because it’s pretty great at dissolving all kinds of unwanted coatings.
![](https://valkyrie.cdn.ifixit.com/media/2024/04/04160559/waterbottle-orange-oil-experiment.jpg)
Orange oil is a popular solvent for scraping away adhesive residue (and it’s one of the things that makes popular adhesive removers like Goo Gone work). After seeing some reports of its effectiveness at cleaning up sticky plastics, iFixit sustainability director Liz Chamberlain tried it on a water bottle that used to be soft and became sticky. A wipe-down with an orange oil-soaked rag, then a rinse, made the finish on the bottle visibly smoother and no longer tacky.
The only way to know which solvent or method will work on your particular sticky plastic item is to test it. Start with isopropyl alcohol, which is pretty benign to gadgets, and go from there, testing on a hidden spot before committing.
As for safety, avoid breathing in fumes, wear gloves, and use in a ventilated space. Dispose of all cleaned-off gunk correctly, and be careful with those solvent-soaked rags, because they’ll be a fire hazard.
And if all this seems like a major hassle, that’s because it really is. Once you’ve scraped and de-gunked one gadget, you’ll be a lot less likely to buy a soft-touch product ever again.
This is the latest in a series of answers to common repair questions: How do I stop stripping screws? Should I even bother trying to fix this stupid, busted printer? I spilled liquid on my laptop—now what? If you’ve got other broad repair questions you’d like us to answer, leave a comment below.
10 comentários
The best solution I've found is corn starch powder, not talc ( carcinogenic) , highly absorbent. Thanks for the job you guys do..
Adrian Paul - Responder
I believe talc has been only been linked to cancer when used on "lady parts". Although decades ago some talc was mixed with asbestos(they are often naturally found together when mined) that issue was addressed long ago. It's fine if you want to boycott talc products because of the neglect regarding issues with vaginal use, but it should be fine to use on your electronics
cuvtixo -
Orange oil: I love the strong citrousy smell, but it can mar the surface of certain plastics, especially noticeable for some transparent plastics. I was using it for taking labels off glass jars and medicine bottles, the results were great, but then a clear plastic water bottle turned an uneven, blotchy milky white! It was a shock after seeing it clean other plastics so well, to a brilliant shine, even. Remember TEST IT FIRST! There are so many different plastics out there. Also, recycling ♻️numbers 3 through 7 are hardly ever actually recycled, it's much too expensive a process. Attempt to reuse these items as much as possible. The efforts to collect these plastics is nothing less than a scam by the industry.
cuvtixo - Responder
Rubbing alcohol has a much lower percentage of alcohol in it. You can buy 99% grade at your paint store. It is also used for stoves that are made for burning alcohol. A good car part or other just metal cleaner/degreaser is kerosine. You can buy it cheaper at your local airport as jet fuel if they will let you buy a gallon at a time. They are used to selling it in the hundreds of gallons at a time.
Jon - Responder
For removing leftover adhesive from bottles or jars I use olive oil, smear a small amount on and leave 30 min, then wipe off. Occasionally a second application is required.
Ian Hayes - Responder
