Despite keeping the same price tag as its predecessor, the new Nano is a bundle of trade-offs. Gone are the days of click wheels, cameras, and video playback. Instead, users get a multi-touch screen, a clip, and a device that’s slightly easier to repair.
Judging by the both the internal and external features of the device, we feel the new Nano is more like a Shuffle with a screen than a Nano with true multi-touch.
Apple is seriously reaching by calling the Nano “multi-touch.” 3M defines multi-touch as the “ability to simultaneously detect and resolve a minimum of 3+ touch points.”
The Nano does not support three touch points. In fact, the only gesture the Nano supports that has two touch points is rotation.
We’ve learned from reliable sources that Apple’s internal documentation suggest support for pinch to zoom, which is not present in this version of the iPod Nano’s software. Was this feature cut at the last minute? Could it be added back in with a software update? Only time will tell.
Teardown highlights:
- This iPod Nano’s battery only has two wires, one red and one black. All the other iPod Nanos we’ve taken apart have included three battery wires. That third battery wire typically ties into a thermistor, a resistor whose value changes with temperature (a poor man’s thermometer). Presumably the iPod Nano’s battery is small enough and the charge rate is slow enough that overheating is not a concern.
- The 1.54″, 240 x 240 pixel LCD screen is equipped with multi-touch, although how anyone is supposed to comfortably fit more than one finger on the display is a mystery.
- The Nano has a 220 pixels-per-inch (PPI) screen, the highest pixel density on an Apple device aside from the iPhone 4 / iPod Touch 4th Gen. That’s almost double the iPad’s paltry 132 PPI density!
- Pure speculation: The front glass on the Nano sticks up about .3 mm from the outer case. Why, you ask? Presumably due to the thickness of the headphone jack. Apple wanted to keep the device as thin as possible, and the curvature of the edges would have forced the case to be thicker for a completely flush glass panel. A thicker case was ditched in favor of the glass sticking out slightly.
- Like its cousins — the iPhone 4 and the new iPod Touch — the touchscreen, LCD, and front glass are inseparable.
- The Nano’s battery has a capacity of 105 mAh, compared to the Shuffle’s 51 mAh. We assume the Nano uses the extra juice to power its display (which the Shuffle lacks).
- The headphone jack, volume buttons, and sleep/wake button are all found on the same ribbon cable that snakes around the inner perimeter of the Nano. Very efficient!
- There’s a total of eleven screws in the Nano — quite a hefty amount for such a small device.
0 comentários
