Introdução
Describe what you will do.
O que você precisa
Unlock the lock latch on the left.
Unlock the lock latch on the right.
Remove the battery while holding the lock latch unlocked.
Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
Lift the bottom right cover with the iFixit Opening Tool.
Lift the lower left cover with the iFixit Opening Tool.
Finally clear the bottom cover completely to access the main components.
Locate the RAM card in its slot.
Spread the leaf springs that hold the memory module in place (left and right).
Remove the memory module (RAM) from its connector.
To reassemble your device, Follow these instructions in reverse order.
Um agradecimento especial a esses tradutores:
100%
irlanda está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
