O que você precisa
Unlock the lock latch on the left.
Unlock the lock latch on the right.
Remove the battery while holding the lock latch unlocked.
Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
Lift the bottom right cover with the iFixit Opening Tool.
Lift the lower left cover with the iFixit Opening Tool.
Finally clear the bottom cover completely to access the main components.
Locate the hard drive with its plastic tab.
Remove the HDD from its SATA port using the plastic tab
To reassemble your device, follow the instructions in reverse order.
Um agradecimento especial a esses tradutores:
100%
Israel está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
